+1 to that, my mate's had 3 cheap psu's die on him and the last one killed board and chip
also have to agree your temps are a little on the high side a new cooler would also be a good idea, also check if there is a dust build up in the heatsink on the cpu as that will cause the chip to overheat as well and might not need a new cooler, unless you plan on overclocking![]()
CPUID HW i see that one of the temps is 79'c do you know what it is as i haven't used that program before, your core temp readings are not at all bad for a 3.2Ghz x2 i had my old x2 6000+ running at the same speed and was around the same temp so i would say it's possably not that but they are not 100% load temps, could you post a pic of a 100% load reading
the ocz psu above should do you just fine, can't remember if i said above but i've got a 600W ocz gameXsteam firstly running my 6000+ x2 and 8800gt sli and at the mo running my current set-up and it's about 18 months / 2 years old now and still going strong
also silly question but you do have a surge protector on your pc don't you, i ask because a mate of mine who's been into pc's for years and has only just got round to buying one![]()
yes defo get a surge protector, as for your gpu my idle temps are 45 for one and 38 for the other but i'm running gt's in sli and a custom cooling setup with about 10 fans, and yes it doe's sound like it's hovering but it's in a vented box with lid so can make quite when watching a film or 5.1 headset for gaming so noise not really a problem lol
grab a program called occt link there are loads of tests in the new one one of them is a psu test, it loads the system to 100% and also has tests that test and log temps of cpu and gpu
run a few of them and post the logs here so we can check out if there's anything wrong
thanks again to all^^
