I have posted a few times in the last few days.
Still a touch undecided about doing this but if I can get a good system for ok money then I may well pull the trigger.
Remember its to replace a H80 thats been messing about.
I am looking at adding in one of GTX 580's as it gets very hot in the 650d case, when they are both running hard with a decent oc
The other (bottom) never gets above 65c even under a big oc so there is no need to water cool it.
I am after a double rad based system and need it to cool my oc 2600k as well
I have looked at this kit and it seems ok + a few extra bits to make it up.
I am not necessarily after class leadin performance - more to get me going and to perform as well as the H80 which is pretty good!
My basket - what else do I need?? More tubing / connectors?
EK H3O Watercooling Kit - Supreme HF 240 **2011 Compatible** EK H3O Watercooling Kit - £158.98
EK FC580 GTX+ Full Cover Waterblock - Nickel **EN Nickel Plating**
Mayhems Ultra Pure H20 Watercooling Fluid 1L Mayhems Ultra Pure H20 Watercooling Fluid 1L
