I didn't ever plan to watercool ,I am looking at it as a result of having a faulty h80.
I am reluctant to use another one, but see little alternative - my temps with it are actually good max 75c with 1.45v on prime.
With an offset oc my general load temps dont go above 50c approx. I dont want to buy something else and get worse temps, what would be the point of that.
My top gtx 580 does get hot in my 650d in real demanding games such as crysis 1 & 2 fully maxed or benchs etc. This is because the coolers on both 580s output a lot of their heat into the middle of my case - a lot of their heat distribution comes out of the back of the cards, rather than out the back of the case.
The 650d has no cool in airflow at it's back or middle therefore my top card gets starved of cool air as the case cool air intake(200mm front intake over hds) meets the cards hot air output if that makes sense in the middle-ish of the case.
That heat rises and is vented out the top by the 200mm
I have tested - by taking the side of the case off and my top gpu temps drop 10+ degrees at 100% load.
That is my target for the gpu and allows me to overclock more
This will be more important in the future when games become more demanding or I buy a 120htz monitor.
I therefore was looking at using water to cool my top gpu and CPU to make spending another few hundred pounds worth it - I was hoping to get equal cpu cooling to the H80 - I will be happy with that but also cool my top 580 at the same time.
My top gtx would then not be using any case air to cool, and using my loop.
My target temps are 75c max 1.45v 100% load CPU
And 80c top gpu with a decent amount of volts and overclock.
I presumed to get better temps than that, but you are all say no?? if thats the case I might as well keep my money / the H80 and get the side mesh panel and maybe a 180mm fan.
I dont really want to do that as its ugly + watercooling is new and exciting, however I am not prepared to buy anything else new i.e. case or anything just to watercool. (Obviously will happily buy the bits for watercooling)
This will be more important in the future when games become more demanding or I buy a 120htz monitor.I therefore was looking at using water to cool my top gpu and CPU to make spending another few hundred pounds worth it - I was hoping to get equal cpu cooling to the H80 - I will be happy with that but also cool my top 580 at the same time.
