Help with an upgrade
13 Dec 2008
Hey all.
Looking at getting an upgrade for my Q6600 this xmas from the wife and i just need clarification on a few things. I already have my HDD's, GPU, PSU (potentially, its a Corsair HX550. i think its ok for what i need) sorted but i need to make sure im not forgetting anything.
MOBO - http://www.overclockers.co.uk/showproduct.php?prodid=MB-521-AS&groupid=701&catid=5&subcat=2265
CPU - http://www.overclockers.co.uk/showproduct.php?prodid=CP-406-IN&groupid=701&catid=6&subcat=1275
RAM - http://www.overclockers.co.uk/showproduct.php?prodid=MY-363-CS&groupid=701&catid=8&subcat=1390
If anyone can confirm that what i have selected is ok and if they could recommend anything else? My budget is around £300.
Thanks in advance
YOUR BASKET
1 x Intel Core i5-4670 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £169.99
1 x MSI Z87-G43 Gaming Series Intel Z87 (Socket 1150) DDR3 ATX Motherboard £94.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLD38G1600HC9DC01) £53.99
Total : £328.57 (includes shipping : £8.00).
Slightly cheaper in case budget can't stretch too much right now, but processor isn't overclockable. If you want overclocking options, get the CPU* Fowler recommended.
* Edit: And the Gigabyte mobo with cooler too.
YOUR BASKET
Slightly cheaper in case budget can't stretch too much right now, but processor isn't overclockable. If you want overclocking options, get the CPU Fowler recommended.
going with the 4670k with that motherboard will require a third party cpu cooler making it similar/more than(depending on the cooler chosen) than what I speced.
Yes. If my budget could stretch enough to go for the K, I'd definitely get the Gig mobo with cooler you recommended also.
I have a 3rd party cooler. Would i need to purchase a special one though for the k?
well this is what your basket looks like with your chosen bits
YOUR BASKET
1 x Intel Core i5-3550 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £164.99
1 x Asus P8H77-V Intel H77 (Socket 1155) DDR3 Motherboard £91.99
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Memory Kit (CML8GX3M2B1600C11) £71.99
Total : £338.57 (includes shipping : £8.00).
that's only £27 less than my suggestion, I'm sure you can find the ~£30 extra from somewhere. don't go out drinking for a day or 2 or something.
well it depends if it supports 1155/1150 socket, the q6600 is socket 775.
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £185.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Patriot Viper "Sapphire Blue" 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (PV38G186C9KBL) £59.99
Total : £365.57 (includes shipping : £8.00).
that would be better, little over budget but will last longer than what you've posted(tho ram twice).
Haswell is happy with faster RAM, with prices so close it just makes sense to get the faster kit (your 1600Mhz choice is in fact more expensive). Only real mistake Fowler made was forgetting the free P&P ;)
You can always consider the OEM i5K which is slightly cheaper. Yes it has a shorter warranty but let's be honest CPU failure is very very rare and you don't need the stock heatsink as the D3HP comes with a decent ~£30 heatsink to allow overclocking.
If you have a decent heatsink already that fits the 1155/1150 socket.....
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £179.99
1 x Gigabyte G1.Sniper Z87 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLD38G2400HC11CDC01) £59.99
Total : £359.96 (includes shipping : FREE).
Much better onboard audio and it's Xfire/SLI capable (you'd need a stronger PSU to use that feature though). It really is a ridiculously excellent value mobo for the money. I'll whack in an AMD spec as someone is bound to point it out as an option.......
YOUR BASKET
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £119.99
1 x Asus M5A99X EVO R2.0 AMD 990X (Socket AM3+) DDR3 ATX Motherboard £109.99
1 x Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) £53.99
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler £29.99
Total : £313.96 (includes shipping : FREE).
