- 25 Jun 2022
- Peterborough
I could really do with any advice, as I'm getting a bit stressed about it now.
So, a decision has been made to just fill the room with adequate sound for the occasional movie on an 85" TV.
I'm going to go for a budget 85" of around £1500, and hopefully I will find something I will be happy with.
Soundbar-wise too, I'm thinking around the £600 mark if that's possible, but with a separate Bluetooth base in the corner?
I think I am considering something simple and cost-effective. I don't have the possibility of putting a shelf for a sound bar under the TV as I want the 85" TV to rotate towards either the left or right on a really slim strong bracket which I am yet to find anything suitable which pushes back slim enough - any ideas?
The soundbar needs to pack a "bit" of punch
(I can use headphones for the treadmill but how would I connect Bluetooth IF watching from the firestick on the TV? ), but I've never purchased one before.
I'm at first fix with the builders for another couple of days, so I could, in theory, plug in a power cable and an optical cable too, for sure. I think that would be sufficient.
Can a sound bar be installed and "does" it need to rotate with the TV? OR simply leaving it in situ against the wall is good enough?
I need to find a good enough soundbar where I could;
Bluetooth from a phone Select optical so the TV comes through it?
Amazon Firestick hopefully can play through the sound bar?
Thanks for any advice
