Help with new build
18 Jul 2004
ok, ive put everyhting from my new build together, but when i turn on the IO switch on the psu and press the on button nothing happens, there is nothing indicating it is on
specs
e6300
gigabyte ds3
x1800xt
geil ddr2 2x512 pc5300
i have tried it with one stick of ram but it hasnt helped
any suggestions?
kicks66 said:
which ones are those? i have some that have VCC on them and some that have L RET L OUT etc
Those are the ones with a white cover right?
The speaker is usually a red and black wire (twisted together) that says 'speaker' on it. Should have 4 pin holes.
Beenom said:
:D
Also, i think you require a 4pin power plug near the cpu socket (Atleast my P5W does). Is that plugged in? (If you require it that is!)
yep hte little 4 pin plug near the cpu is plugged in from the psu
Pretty sure the VCC ones are the USB connectors. The speaker must be the L RET and L OUT :)
nope, i have a load of little black covered things, none say speaker on
also, in the manual it talks about a power led, but i have nothing to plug into that :/
fenderbass86 said:
Yeah you do, mine sits uncomfortably next to my Arctic Freezer 7.
And I have to slide out my motherboard tray if i want to connect it because the big typhoon is huge. :rolleyes:
