help with setting up for 02/be
23 Feb 2004
Greenside/Tyne & wear
I'll need some help with my router when I get connected to 02 on wednesday, how easy is it to actually use my existiong netgear DG834g instead of the o2 box. can someone give me so settings & a procedure so I can print it out... not to good with routers at all but I know I dont like the thompson stuff (home hub & the 585v6 gave me crap)
Thanx
Kev!
O2 said:
How to set up O2 Broadband on your own router
If you’re using O2 Broadband with your own router, you may need to enter some settings for it to work properly.
Some routers come set up correctly. Others will come with a set up CD or wizard to help you get connected. You’ll need to refer to the manufacturer’s instructions to find out exactly how to enter these details.
If your router has an ADSL2+ setting, make sure it’s enabled. ADSL2+ is the technology we use to get a high-speed connection into your home.
These are the other settings you’ll need to enter into your router:
* ISP name: O2 Broadband
* Multiplexing method: LLC-Based
* VPI: 0
* VCI: 101
* Username: leave blank
* Password: leave blank
* Domain name: leave blank
* IP address type: this depends on whether you chose our static IP address option or not:
- If you didn’t choose our static IP address option, set this to dynamic IP
- If you did choose our static IP address, enter the IP address printed in your welcome letter
* DNS servers: choose to get these dynamically from the Internet provider
* NAT: enable
Once you’ve entered these, you should be able to connect your router to your landline as described in the manufacturer’s instructions, and get online. Please note that if you have problems using your own router, we can’t offer any help to fix it.
That’s why we recommend you use the O2 wireless box II – it’s been designed to work with O2 Broadband, and we offer full support. So if you have a problem, we’ll be able to help.
Hope that helps :)
the above instructions are spot on, and i have my be* running through a dg834g and it is rock solid! good luck! :)
I was gonna use their router for afew day to start with but do I need to install their cd as I really dont want isp software on my machine, I remeber how bad freeserves/AOL rubbish was
Whilst on the BE setup subject, does anyone know how you would get a SpeedTouch 536 to work with the BE service?
It requires a username and password to get past the setup pages and it will not allow me to leave it blank.
Try putting anything in the box?
Yes but still no connection to net, does however allow me to get through the setup pages.
Does anyone know what settings to use in the images shown above? Such as PPoE or PPoA etc..
The only numbers I have are
Static WAN IP address
Wan NetMask
Gateway IP address
and primary/secondary DNS servers, but as you can see above it uses different terminolgy and I dont know what goes where.
This is for connection to BE's service.
The "Service Provider" option won't work - you need 0/101 for Be, not 0/38.
Wan NetMask
Gateway IP address
None of the boxes you've shown are for that information. The second and third boxes are looking for information for the LAN.
