Help!!!
But the mobo is compatible with IB!!! They can't advertise a product saying it works with IB if you have to buy a SB CPU first before you can use your IB!
Nothing to do with cpu.
2 bleeps is memory problem.Most boards don't like Crucial Ballistix.Try different ram or 1 stick at a time.
Check cpu cooler and thermal paste on the cpu.(good contact)
Clear cmos(take battery out from board leave out for 1 hour)
Also can be psu problem
it says in the list that the G440 needs bios F6, does this mean it needs to be updated to F6 or will it work straight out the box? I don't want to spend £30 on something I don't want only to have the same problem with that! I might try my local shop.
Really? I've tried every stick seperatly but it still didn't work. I've tested my PSU and that's fine. I'll try the cmos, does it have to be an hour?
Leave at least 30 mins.Try different ram not ballistix.Check the graphic card.pull out push back in,check connections.
taken from gigabyte forum with some1 same problem as you
I had exactly same issue with my GA-Z68XP-UD3 and i5-3570K. The problem was the old BIOS version, which didn't fully support IB CPUs, so I had to flash a new one. You can't do this with your CPU, because it keeps rebooting and you are not able to start the Q-Flash. You need to get a SB CPU and then flash a new BIOS. The BIOS version you need for your new CPU is at least "FC" in your case, so check the version you have. Be sure to reset your BIOS after the flashing and then load optimized values. It should be able to boot up with your new CPU properly then
that was some1 telling him what 2 do
