- 17 Mar 2004
Whoop, guess I'm on the hunt for some Focus xenon headlights then. It's the only real thing that's been bugging me ever since I got the car.
Do you have a ST1? Never seen one
I got an HID conversion kit (5000k) off ebay for my Civic Type R and have just fitted them, I will get a picture when it gets dark. So far they seem a lot brighter.
Only down side is my side lights look orange in comparison, so I have bought some white LEDs.
As promised:
Very pleased with the results, I think there needs to be a little adjustment to make them perfect, but at least they aren't blinding people.
Did you fit yourself?
Just wondering how difficult it is to fit something like this: http://www.ebay.co.uk/itm/BMW-CANBUS-ERROR-FREE-H7-XENON-HID-LIGHTS-CONVERSION-KIT-BMW-E46-E60-E81-/230917924836?pt=UK_Cars_parts_Vehicles_Wheels_tyres_trims_Valve_Caps_ET&hash=item35c3c7e7e4
Yer - just fit them.
There appear to be more ****'s on the road these days then regular sensible drivers - might as well go join the majority.
The self leveling system doesn't stop the lights bouncing up and down over bumps either, it levels the lights depending on the load over the rear axle.
OEM ones do, at least on a Skoda Octavia. And I think it's the same on most OEM systems.
Sure it won't move quick enough when you're doing 90mph on the motorway but in town traffic over speed bumps they make a huge difference.
Find info here for the MOT, think it will be in from April:
http://www.transportoffice.gov.uk/c...nualsandguides/mottestingmanualsandguides.htm
As promised, complete retrofit instead of putting HIDs into Halogen projectors.
The light output is better distributed and brighter than before, the picture does not do it justice.
You can see i am not as close to the wall, but the light output and the cutoff is so much better.
