Home Assistant beginners
Thanks. I'm still tinkering and finding my feet with this. Cheers.
I looked at doing something similar a good while ago. ApexCharts has options to reverse the Y axis for a series and also auto-invert data points for a series so you don't need to create a new sensor for it. I did get it working but it just didn't look right for me because I was trying to show daily energy usage and the gas usage varies quite wildly throughout the year (almost no usage in summer, maximum usage in winter) where as electricity is fairly consistent all year. In the end I opted for two individual column charts that were stripped down to look more like the mini-chart-card. minimalistic/clean but with actual numbers on the columns to show usage.
Also just in case you haven't seen this yet, almost all of the ApexCharts config options will work in this card too even if they aren't listed on the apex-charts-card GitHub page: https://apexcharts.com/docs/options/
Got Home Assistant installed on a Pi5 with a M.2, PoE adapter board.
It all seems to be working, connect a monitor and it says it's running and has an IP to proceed via browser or app.
But I can't connect tried both http://homeassistant.local:8123 and the IP version. I can ping both no problem.
I can connect to the :4357 and everything is correct.
I get an Error Code -6
net::ERR_CONNECTION_REFUSED
Yes i tried all that, i have it running on my NAS as well and no issue accessing that so it wasnt network related.
Fixed it in the end with this set of commands.
ha > core stop
ha > login
# cd /mnt/data/supervisor
# mv homeassistant homeassistant_borked
# mkdir homeassistant
# CTRL-D (drop back to ha shell)
ha > core rebuild
ha > core start
And it worked, all sorted.
Just installed LLM and Gemini AI.
Very easy to do, just going to have a play with some coding to see what it can do and what uses i can make of it.
Anyone else running AI and what are you using it for?
hi all.
I reckon this is a simple issue but I can't sus it out even with the help of google!
I have an automation set up, to turn some lights on 10 mins after sunset - then a 3 hour delay then they turn off. Fine for summer, but I would like to have a condition where they stay on until around 22:30. How would I go about doing this?
At the moment it is as follows:
When
When the sun sets
Then do
Delay for 10:00
Switch 'Turn on' on Porch Fascia Lights
Delay for 3:00:00
Switch 'Turn off' on Porch Fascia Lights
hi all.
When
When the sun sets
Then do
Delay for 10:00
Delay for 3:00:00
Try the following. Obviously change the light to your porch light. EDIT: I’ve only quickly thrown this together but it should work. If it doesn’t then it’s a sound basis to work with
YAML:
description: ""
mode: single
triggers:
  - trigger: sun
    event: sunset
  - trigger: sun
    event: sunset
    offset: "3:0:0"
  - trigger: time
    at: "22:30:00"
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - PorchLightsOn
        sequence:
          - action: light.turn_on
            metadata: {}
            data: {}
            target:
              device_id: 2e0e68dab574f2dd7c44621091dd1f88
      - conditions:
          - condition: and
            conditions:
                id:
                  - PorchLightsOff
              - condition: time
                after: "22:29:00"
        sequence:
          - action: light.turn_off
            metadata: {}
            data: {}
            target:
Really happy with it so far. Lights seem to respond faster than they did via Hue.
Bonus of powering it via POE is that a van very easily cycle the power remotely should I need to.
Question, I mistakenly set the boot up to m.2 first then SD card in hindsight I should have left it as SD card first. How do you get back into the settings of a Raspberry pi while using Home Assistant?
I've got a frustrating issue with Home Assistant and am not sure when it started.
We've got a recessed ceiling in our living room which has an RGBWW LED strip in it, HA has been happily talking to that strip for a few years using the Magic Home integration. Last week I noticed that the LED strip was showing as unavailable. However, it's just HA that's having issues here. I see the LED strip online in UniFi (with the same IP that HA has for it), the Magic Home app sees it and can control it fine as can Alexa.
So network connectivity looks fine, zero packet loss but HA still doesn't like it. This morning I removed the LED strip from HA, told it to discover but it couldn't find it. I gave it the IP but again, it said it couldn't discover.
Is anyone else using Magic Home and having issues with it?
YAML:
description: ""
mode: single
triggers:
  - trigger: sun
    event: sunset
  - trigger: sun
    event: sunset
    offset: "3:0:0"
  - trigger: time
    at: "22:30:00"
conditions: []
actions:
  - choose:
      - conditions:
            id:
              - PorchLightsOn
        sequence:
            metadata: {}
            data: {}
            target:
      - conditions:
          - condition: and
            conditions:
                id:
                  - PorchLightsOff
              - condition: time
                after: "22:29:00"
        sequence:
            metadata: {}
            data: {}
            target:
Thanks mate, I'll see if I can work out how to edit the yaml and try it out - I'm pretty new to HA but slowly starting to find my way around it :D
Does anyone know a way of setting alarms via voice on the HA Voice PE? i.e. saying "set alarm for 9am tomorrow"
It's the last big thing on my want list for HA.
Start a new automation then click on the three dots at the top right. Select "Edit in YAML". Copy the YAML code I wrote and paste it into the text field. Change nothing!! Then select the three dots again and this time "Edit in visual editor" which should take you back to the easier to use editor. YAML can be a pain to copy and paste due to indentations but it should be OK.
Haven't done anything with the dashboard yet, not something I use really, it's more behind the scenes functions.
I like the idea of a wall mounted screen with it all on eventually, heating, lights and CCTV.
I had a quick look there doesn't look a way of bringing smart meter info into HA.
No, even though your smart meter may have the Zigbee logo on, its a proprietary form which cant be read and integrated into HA. If you have an Octopus Mini, that would do it, or some CT clamps linked to something that can integrate. Quite a few ways. Think I'm using my Zappi car charger for the grid in/out measurement.
Here's a load of mine.
https://i.~ibb.co~/Nnk4nNs5/image.png
https://i.~ibb.co~/cSsmwzF6/Screenshot-2025-11-07-183747.png
https://i.~ibb.co~/RpqC2Y04/Screenshot-2025-11-07-183840.png
https://i.~ibb.co~/8npxMB7M/Screenshot-2025-11-07-183929.png
And then this one is for controlling lights thats on a touchscreen linked to a miniPC in the lounge.
https://i.~ibb.co~/9mTDDZcV/Screenshot-2025-11-07-184058.png
Think I have an Octopus Mini, little purple/pink device for live data.
I had thought linking to the Bright app would work, seems a few people got that working but doesn't look easy.
Bright app linking was easy enough, from memory. I couldn't do it any other way as I'm in a building where my smart meter is out of signal range. The HA integration however, I think was deprecated for a bit or stopped and was picked up by a different person.
