Using temp controlled fermentation and proper yeast pitching will get your kit brewing as good as it gets.
If your going to get in to extract brewing you can also try a Saison which requires higher temps (with the correct yeast) or some Belgian's as well as lagers.
Would you always recommend rehydrating dried yeast before pitching?
I keep seeing the Saison style come up around the home brew sites but i don't think that i have ever tried it, i think i might have to get down to one of the specialist beer shops and pick up one to try (luckily Newcastle has a few good places and bars that carry stuff from all over).
99% of the time you should rehydrate before pitching, yeah.
The only times you might not consider it would be if you were pitching a smaller batch of (for example) wheat beer and you want to 'stress' the yeast in order to produce more phenols during the early stages of fermentation.
Other times would be when you're in a massive rush/lazy![]()
Pitching your yeast dry will kill about 50% of it.
If you can get any of the Dupont Saison's I would try that I believe it is made with 100% pilsner malt with Styran and East Kent Golding hops, I have made a Saison with just EKG hops and it's quite close to Dupont.
If you want to try and a brew Saison then Danstar Belle Saison is a good choice of yeast, you will need to keep the temp up as if it drops it can stall. Starting at 18-19°C and raising 2-3°C per day 24 hours after pitching to reach 28-29° then hold till finished + a few days will work.
You could look at hacking a lager kit.
If you want tops for these Sainsbury's stock them, I've had a look at them and they seem to be a quality product.
I see you have joined the craftbrewing forum foob4r most of the members are ex thehomebrewforum it's a good resource for home brewing not that you should not visit here as I do from time to time. I'm jimmy321 on there also.
Good to know, i have been doing a lot of research but was leaving the details of the yeast pitching until i knew what i was brewing as i wasn't sure how specific it was to the yeast being used.
I will definitely try out a Saison Dupont for *cough* research purposes
Holding temperatures should not be an issue as i have a greenhouse 60W heater also being controlled by the STC-1000 (i have been cooking using a SVS water bath for a few years now so realised pretty quickly the value of decent temperature control, especially after doing measurements around the house/garage and then thinking about the seasonal aspect).
Does anyone have any recommendations for beer software? I know that i need to log my brewing if i want to get consistency and improve batches, bits of paper just won't be a good idea for me (synching between devices is a bonus). I have had a look round at Beer Smith etc but just wondered if anyone had personal experience.
Brewtoad is pretty decent though it was a lot better before they 'improved' the interface/site.
Do you have to add more/less yeast based on the amount of sugar that goes into the brew?
Interesting. I was at a new micropub last night and they've introduced a thing called Tap takeover where they only sell beer from a particular brewery for a couple of days and get someone from the brewery to come along and give a bit of history of the brewery and their processes.
I got chatting to a guy who has a microbrewery in his garage so we got talking about brewing and i explained my initial failed attempt and how i was having another go.
He explained that the water in Chorley is terrible, and whenever he makes a batch he goes to his daughters house over in Burnley and fills a couple of plastic bottles with water to use during the brewing process. I've also read a few things online about people using bottled water.
How big a difference does water actually make?
Would that make as much difference with a kit as when doign all grain? I know the pH and ion compostion make a difference during the mash and boil, but with a kit that's already happened. So long as there aren't bad flavours in the water and too much chloramine, beyond that it is worth all that extra hassle with a kit? If your water is really bad, then sure.
I'm not disagreeing, I actually don't know and would be interested in your experience Frenchtart.
