That looks great, colour aside. Buy that one.
Already in discussions with Roush about what they will make available so one can build their own 729 car.
Not a fan of the colour and I normally hate wide arch kits, normally tacky, but Roush have simply nailed it, best looking Mustang I've seen full stop I think.![]()
Fishing for a discount![]()
Why does the Rpm start with a 0. That would annoy me
The lag on the digital display would annoy me much more. Give me an analogue gauge cluster any day thanks.
Why the 160 on the speedo when it's electronically limited to 155 ? You can go on.
I like the way that the numbers on the rev counter are a darker shade, then as the needle approaches a number it brightens, gets it's brightest as the needle is on the number, then darkens slightly again as the needle goes past the number.
The same on the speedo side.
It's a nice touch and attention to detail that I like, and if you don't like the grey/white then change the colours, you can have blue, red, green, orange, or other colours in the My Colour menu, can't do that easily with analogue gauges.
As to not needing zero so why is it there, you do not need the 8 either, never revs that high so why put that in ? Why the 160 on the speedo when it's electronically limited to 155 ? You can go on.
