Permabanned
- 3 Jul 2008
- My fabulous ship
WHAT!? TTIUWP!!!!!
Hate the dentist myself! Not been since I was 15 (22 now) - don't intend on going anytime soon either!
Something else. Does anyone eat on both sides of the mouth when they chew?
I used to but when I was a nipper my tooth started to crumble (but feared the dentist so much) so I started to eat on the oppostie side for months before going. So now after about 10 years I only ever chew on my left hand side. (current broken tooth is on the right)
You'll regret that in a decade, it puts a lot of pressure on your jaw bone and rapidly accelerates the degradation of the joint between your jaw and skull.
I'd be interested to know how you get on. You should put up some before and after pictures. Its something I've thought of doing. How much is it going to cost you?
I will let you know. I will be taking before and afters but whether I post them on here or not is highly debatable.
I am getting 10 crowns, whitening, couple of root canalsand it's going to cost about £3700. That is for the high quality Procera crowns. For the more standard crowns it was going to cost about £2500.
That is just for the top. The bottom is not too bad and I have seen the smile design and am pleased with just getting the top done. With the bottom as well it looked a bit too perfect for my liking but then again I can always get that done later if I change my mind.
Massive savings and a very high standard of dental care. I'm looking forward to a nice week in Budapest as well. (albeit with an agony mouth)![]()
So happy my teeth have a really low decay level. 27 and everything in my mouth is 100% natural.![]()
This was an option for me, but I decided that having a big open area where food could get stuck wouldn't be so nice.Just get it pulled out.
Update :
Went to the dentist...He drilled a BIGGER hole into the tooth and said...Yep its fine. Just make sure you try to eat on the right hand side too...Overall nice teeth and gums. Result!
Although...I dont know if ill be able to eat on the right...Not with a hole even bigger than before!! wtf
Weeeird!! Mine did that today too.. but then he filled that in with fillingYou sure you're dentist didn't kinda forget that last bit?
