How do you decide how to modify your car?
18 Oct 2002
As above,
what order should you do your mods in, and how do you choose what to get?
currently, im trying to plan out how id like to mod the puma.. and to be honest, im confused as to where to start !
the car as standard is known for its good handling and brakes... so...
do I do all these mods first, and then move onto the engine.. or do I do the engine first, and then do *** brakes and suspension last?
my plan was to do the suspension, then brakes, then engine....
rite?
Yes, upgrade the suspension and brakes to make the most of the power you currently have, then when you add more you have be ability to fully use it ;)
Depends on what your doing long term tbh, no point in bigger breaks if your not going to be giving it big power. Better pads and discs will do :) What do you want from suspension? just lowering or to improve handling? either way that can be done at any time but if your giving it a lot more power then stiffening up the rear would probably be best done before hand.
All depends on your long term plans imo.
Whichever you thing is most important first. If you want handling, fit suspension mods, if you want ICE, fit a better HU, etc
Brakes should be first, uprated pads, lines and fluid...
Tyres/Wheels can go here or before brakes...
Suspension next...
Intake and exhaust next...
Re-evaluate braking performance
ECU upgrades to follow...
Then you can go for porting etc...
Visual can go hand in hand with those mods... as budget tastes allow..
:D
basically, i dont see myself doing anything too crazy... but I MIGHT supercharge it if the guy at work can sort out a reasonable price (he's looking into it now) no idea what sort of power that might give tho...
if I just go nasp, it'll be about 160 bhp (40 more than stock)
I guess the best thing to do is to ask the owners clubs what they recommend.. anyone know what the big puma owners club is?
Personally, I drive into the front window of Halfords and anything that sticks to my car is what I get. Simple
Hi there,
Get signed up to PumaPeople forum - there are some great people there who know wayyy to much about Pumas and modding.. very good info and advice.
Also check out Puma Build and Puma Speed!
I started off with the standard ICE upgrade (amp/sub/headunit). Then fitted new 17" alloys/tyres and Pipercross induction kit and clear indicators.
However the main mod I've always wanted to do (and will be doing in May) is fitting AVO Sport Evo GTZ Coil Over Kit :cool:. I'll probably fit decent spark plugs and ecu tweak (+10bhp) at the same time.
Good place to start
Assuming that it's a 1.7, then there are any number of options. If you are just talking about mild power upgrades for the engine then you brake upgrade could be as simple as a set of decent fast road pads. However, if you are heading for major power then you'll need to look at disc/caliper changes as well.
I'd strongly suggest talking to Tony at Pumaspeed (see link above) to see what he reccomends, he's a top bloke who knows Pumas inside out and will help you choose what's right. (From what Sam says, Pumabuild are pretty good as well and probably a bit closer to you),
I dont think there is a set path for all cars TBH. I would start with the weakest link on the car, for most cars they would be the brakes.
cheers for the posts guys :)
Duke - the induction kit, does it sound much nicer? I love the noise it makes at about 4.5k rpm, and would like to make that louder, without being deafened and loosing power ;)
Evo - yeah, I crashed the focus, ford offered me a great price for my focus even with the crash damage, so ive gone for a 1.7i Puma (believe its a 'Thunder' Special edition) ... really chuffed, collect on thursday eve
Will be the longest few days of your life waiting to pick it up :P
Problem you have when a car is so well rounded is where to start :/
More power is always nice though :)
