Just checked mine again you need to run Atsiv & Coretemp-statup before running the main programme.
Rob
You can use speed fan but you will need to add 15c to temps being shown, as it seems to under rate the temps.
Bizar, try task manager just to check that the original process is not running, then try extracting the download to a new folder, just in case.
Rob
the CPU temps are indicated as Core 0=25C,1=23C,2=20C,3=24C
You will need to add +15c to those temps
Seems to be rather high for GO stepper.
Have you rechecked your Tuniq? Or have you applied a fresh application of Artic?
What's your case cooling setup?
I have just got the same chip as you, with an Arctic Freezer and currently idling at 37,36,33,33 after just stopping 3 hours Priming. I'd expect the Tuniq to peform better - does it not come with compound pre-applied?
Plus, did you say you were at stock? I have a 900Mhz overclock with my temps!
Reseat your cooler with the specified amount of compund, applied horizontally.![]()
This guide will help you Admiral Huddy posted pics how to apply the TIM.
http://forums.overclockers.co.uk/showthread.php?t=17800415&highlight=applying+thermal+paste
Try the Arctic guide and see if that gives you better results.
What is important the Artic silver has to have time cure, The silver needs time to embed. This also applies to MX
Temps are somewhat high after new TIM application. As a suggestion give a couple of days to embed hopefully you will see a temp drop.
If after a couple of days there has been no change to the temps re clean the CPU with a alcohol cleaner and reapply TIM.
