Yip paste that came with the Tuniq (TX1) will need time to embed
(Soz if i confused you with MX)
is your room cold? if it is then those temps will be about right, my speedfan readings match my coretemp with my E6850 G0
I could still make out the writing on the cpu when i had put the thermal paste on, does this mean it is to thinly spread out?
thought you had to add 15c to those temps though??
ok, i'll do that then.
fingers crossed it will work out fine, but arnt these temps pretty high though either way??
I'll keep you posted
thanks.
The uneven temps are normal for most Quads. Have you tightened the Tuniq down enough? Do you have the fan controller set medium to high speed?
