How much AS 5 on E6600?
18 Oct 2002
Newcastle, England
Gonna apply some Arctic silver 5 to my conroe but am unsure, can i use the blob pea sized in the middle number?
I use a bit about the size of two grains of rice and spread it very very thinly on cpus with a heatspreader.
about 1 & half grains of rice and just put the HS on, strap it down n give it a wiggle. Thats the was it says on the webby.
This stuff is great i have to say - i used it for the first time on Friday and before that my idle temps were aroun 30-33degrees but now even at 3GHz my temps range from 16degrees-27degrees straight out of the bios..:D speedfan says the same too.
I used some equal to about 1 and a half grains of rice on my E6300 and it looks to be working nicely though. It takes 200 hours to properly "break" in though :)
With one of these and a blob of Arctic Silver 5...
Arctic Cooling Freezer 7 Pro CPU.
Does the job nicely too. Full load is about 40c which is good for me. ;)
Cpu fan speed is 1041 rp, core is at stock as is volts. Max load is 38/40c on this E6600.
Sorry mate no thats from Asus PC probe 2. Coretemp shows something like 50c/40c bothe cores. Bios shows more or less the same as pc probe though.
