Seems there are two types of IHS circulating on C2D's, sharp edged and beveled. It's looking like the beveled edge IHS can be very concave. Either way if a IHS is concave and you use the small grain method, you will more than likely end up with no TIM contact at all. Always check with a straight edge before mounting the HSF, especially if you plan on using the above method.Jleo said:LOL
I can definitely understand your apprehension, but this amount works and works extremely well, try it you will not be disappointed, by the way I wouldn't try to spread the As5, I just put the the heatsink down on it give a firm press and then turn the whole heatsink left then right and back to starting point, pop the clips into place job done![]()
daddyorchips said:Jimbo,
Did you clip the 40mm Akasa Blue fans directly on top of the heatsinks that come pre-installed on the motherboard?
Cheers![]()
Can't understand why they put those silly covers on. Bad design.Jimbo said:Yeah just screw em on with the screws that come with the fans.![]()
Look at these, mosfet coolers are around, can't give you a direct link, but they're about a £1 each.nick_000000 said:Well I have the asetek full dual rad kit and you could use cable ties for the north bridge but that solution isn't ideal. I know I don't need to watercool the mosfet but not sure what coolers to use the vantec vga memory ramsinks that overclockers used to have on their site do you reckon they would fit?
I could always buy another nb block if you can suggest one that is more compatible with the loop method.
fornowagain said:Seems there are two types of IHS circulating on C2D's, sharp edged and beveled. It's looking like the beveled edge IHS can be very concave. Either way if a IHS is concave and you use the small grain method, you will more than likely end up with no TIM contact at all. Always check with a straight edge before mounting the HSF, especially if you plan on using the above method.
Jimbo said:Can you post a guide or pics how to do this?
Coolasmoo said:Not sure if your referring to my post,
All i did was get some very fine Wet And Dry sandpaper.
Placed the paper face up on a Worktop with a light sprinkle of water, and held the CPU heatspreader down onto the paper and just kept rubbing gently in a circular motion untill the h/s was flat.
Its pretty daft having to do that to a new CPU but i had no choice really as it was too concave to make any decent contact with the Water Block.
Just take your time and keep checking across the surface with a flat object like a stanley knife blade or anything flat.
Gutsy move, knocking the resale value on a E6700. I'd think twice with a E6600, luckily my temps are similar to yours lapped. Imagine having to do that with an X6800Coolasmoo said:I can confirm this with an OEM E6700
Having just lapped the heatspreader (almost down to copper) it has reduced temps to 27idle 43load
fornowagain said:Gutsy move, knocking the resale value on a E6700. I'd think twice with a E6600, luckily my temps are the similar to yours lapped. Imagine having to do that with an X6800![]()
