- 7 Sep 2020
- Gods Country
I never look at the tariff data……only look for the pylon.
It comes down to that and wear and tear on the battery, but at one cycle a day that's an awful long time.guess it really comes down to whether the slightly better export price outweighs the extra inefficiency of charging\discharging, and obviously it is quite a nice feeling to be basically self sufficient for electricity
Still saves you more money on the import though to be fair......by around 11p for me. Actually it bigger than that really.....if you generate and export you make 25p, if you dont generate and import it you lose 33p......It comes down to that and wear and tear on the battery, but at one cycle a day that's an awful long time.
It's certainly a lot easier than micro managing it, unless you can set up an automated system that's reliable.
The only other problem with Flux is that you now have to be careful with electric use, as each unit wasted now costs you 25p export even if you generated it.
i agree the export now is more meaningful indeed.....export will soon start to outweigh import and standing charge and may now make money per month, rather than possibly breaking even or losing each month against import cost.It does, but some people were being paid nothing for export, or very little, so from a financial point of view if you used all electric you generated, it made no difference, now there is a meaningful export rate it does.
In my case I was thinking of adding air conditioning, the electric would be free in the summer, but now it won't be, as it will cost 25p or even 40p in lost export per unit.
i ran my AC pretty much 24/7 from 1st july through to end of august and still managed to export something like 300 units a month. The comfort far outweighs a few quid lost per month. I reckon if I only used it when I was in, rather than all the time it'd probably only consume about 100kwh per month.It does, but some people were being paid nothing for export, or very little, so from a financial point of view if you used all electric you generated, it made no difference, now there is a meaningful export rate it does.
Octopus export fixed at 15p.....or agile if your brave enoughQuick question - we've just had 10 panels installed for 4kW through a Solax inverter with 10kw batteries and finally an Eddi unit to heat the water with any spare power. We're lucky enough to be on an old Octopus tariff fixed until August at 18.78p/kWh which I figure it's best to stay on until it expires. Any recommendations for a newbie on an export Tariff to sign up for with Octopus short term with I guess a view to switching to Flux in the summer?
Any thoughts/recommendations?
Potentially you could benefit more from Flux due to the higher export rates. Best bet is get on the standard export with Octopus and then go from there. Export takes the time to get approved, swithcing suppliers for import is usually much quicker and simpler.Quick question - we've just had 10 panels installed for 4kW through a Solax inverter with 10kw batteries and finally an Eddi unit to heat the water with any spare power. We're lucky enough to be on an old Octopus tariff fixed until August at 18.78p/kWh which I figure it's best to stay on until it expires. Any recommendations for a newbie on an export Tariff to sign up for with Octopus short term with I guess a view to switching to Flux in the summer?
I was exporting at the the top rate for two hours yesterday, no thought in it all.I know it's been discussed here but no matter your opinion on exporting at peak rates being worthwhile or not, importing overnight for 3 hours during Flux rate always seems worth doing into battery.
If you over-import and have a great sunny day, the extra just goes to export, and if the weather is poor you have charged some cheaper units you can use.
Just my 2c anyway, I'm not totally convinced it's worth exporting at peak rates yet, because the delta on that is fairly small, but at the height of summer with some W facing panels, I think it's possible that you would naturally be able to export excess 4-7PM for the better rates without focusing on doing it.
But not having a battery means you have no choice if your generation exceeds consumption.I was exporting at the the top rate for two hours yesterday, no thought in it all.
