Just tried the new nvflash.exe file up a few posts and after I've used the elevated command window and did what was said before, it says new gpu bios but the window didn't close itself like I read it on the first post. Do I just close the window, restart and reinstall my drivers? It literally took 4 seconds.
When you are flashing, it gives a bleep and then you watch as the little blocks at the bottom add to each other. I think it took about 4 or 5 seconds for me and then it says "Flash successful" or something similar.
Add the lines to MSI AB and then you should be good for upto 1.3V. If you don't add the correct lines (or any lines), when you overclock, it will probably just crash, well it did for me.
You can use AB Beta 18 for this as well and when done correctly, you will need to reboot your computer.
