How to over volt a Titan, a 780Ti or a 780 guide
Sweet and he has a 300% power bios but that is a bit brave for my Titan.
Gregster have you asked for this thread to be included in the useful links thread sticky
There has been several occasions when I have had to search for this top notch guide.
Next, install the MSI afterburner that came in the tools package. Make sure afterburner is not running and find the MSI afterburner folder that just installed.
Go into that folder and open the 'profiles' folder and you should see 2 files. One looks like this 'VEN_10DE&DEV_1005&SUBSYS_27913842&REV_A1&BUS_1&DEV_0&FN_0.cfg' Open that with notepad and add to the bottom
Evening Greg,
I've flashed the BIOS successfully but for some odd reason I just cannot for the life of me find this profiles folder you refer to...
I've tried the MSI afterburner in the overvolt tools folder you linked too and I've also tried the latest AB download but still to no avail :(
Any ideas?
EDIT: Scratch that... I installed a version I had in my downloads folder instead. That's worked a treat.
I'll keep you updated :)
Greg, with the version of AB I'm using it makes no difference when I alter the profile. I've had the 41 message and all seemed to have worked but still no voltage control in AB???
Downloaded Beta 16, there's no profiles folder :/
As in don't exceed 1.3v on AB? Yeah I hadn't planned to, I really don't fancy pushing too hard :)
I'll finish the rest of your guide before I tweak anything though anyway. Apart from the Zawardo bit :D
AB allows you to go to 1.3V and with the extra from the flash, you will be hitting 1.325v if you max it (which is fine).
The Zawarudo mod is sweet but the version I supplied isn't compatible with this AB but there is a newer one which works with AB beta 16.
Shame I seem to have hurt my 2500k though, it used to bench happily at 5.46GHz but now I can only get 5.1GHz... guess 1.6+ volts wasn't ideal :p That's hurting the benches now!
Those volts are nuts :D
And you have to remember that the 780 will be pushing your CPU when benching, it will pick out weaknesses in an overclock more so than say a 660 would.
Probably anyway, as I imagine more stress on the PCI-E lane.
