How to overclock a 7850 past 1050MHz?
MSI Twin Frozr III OC
How is this looking Ladies and Gents?
1200Mhz on the core
1210mV (drivers crashed @ 1200mV), 5500 Mhz memory clock
63'C under load, 27'C idle
77% Asic
All on auto fan profile, any suggestions for setting one up??
Pretty impressed by this card, first day on the red team.
Here's my score, with out MVP.
With MVP
1000/1300 with stock volt :) im happy with it.
Idles @31C/59C under load.
Wow, >195,000 thread views and I only asked how to overclock past 1050MHz. More people have viewed this than have read the 6950/70 flashing sticky at the top of the section.
The 7850's are without doubt the best card this round, now with them being £139 makes them amazing value when a reasonable overclock sees them battling with overclocked 580's.
MSI R7850 Twin Frozr 3 OC
1225/1450 @ 1.22v
has anyone bought one of those 7850's which uses the ref 7870 board yet?
I am thinking of getting a 7950 but with my overclocked 7850 at 1200/5800 I dunno if it's worth the "upgrade"
1225/1450 @ 1.22v
Just ran this benchmark! same settings on a 580 with a modest overclock for comparison and scored 1638. Frames avg! 65, what are you classing as a reasonable overclock on a 7850?
OK what comes first:
Heat Issues?
or
Graphical tearing/glitches etc?
Got a Sapphire 7850 and overclocked it to 1050MHz & 1300Mem @ standard 1.08v, underload temps barely get into the low 60s if that. Gonna try and get more juice from it but worried about glitches and/or heating issues and wondered which one generally comes first!
Thanks
Is it still better to get 7850 instead of 7870 ?
Yes. Both cards will overclock to similar levels, and clock for clock there is only 5-10 real performance difference between them. Given that the proce difference is ~£40, the 7850 is still the better card.
I also think that the 7870 and 7950 are too closely priced to choose the 7870. There is a much wider performance gap between the 7870 and 7950, but the price difference there is also £40-£50.
So, forget the 7870 unless you can find a real bargain and choose between the 7850 @ ~£150 or a 7950 @ ~£240.
