Just bought one of these so gonna need this guide, how are the Msi Twin Frozr OC versions clocking, anyone got one?![]()
Basically it's good, I got mine up to 1200/5800 @1.185v and it's stable in BF3 and Crysis 2 for hours. Temperature below 70
and it has been there for the past 2 days too![]()
It seems that I am currently the only person in the world who is able to benchmark an air cooled 7800 @ 1400MHz and run 1350MHz rock stable.
It must be a case of ying and yang. Several years ago I obtained the worlds worst overclocking GTX480, plus I have owned plenty of other duffers in the past too. I suppose it is only fair that things balance out.
Come on guys, someone else post some >1400MHz suicide shots.
P7807 @ 1400 / 1500
edit: and for fun, here is how my old stock GTX580 performed vs the 7850. Also, here's a 930MHz core overclocked GTX 580 compare.
It is a Powercolor referernce card (the cheapest 7850 I could find). I changed for stock cooler for an Accelero Twin Turbo II (~£30), and flashed the BIOS to an ASUS DCUII TOP to unlock 1.3v. Check this post for piccy's (results there were listed before BIOS flashing).What voltage are you running it at? And which model is it?
Card is currently running at 1325MHz / 1450Mhz @ 1.275v for 24/7 clocks, but it can run 1350 / 1500 @ 1.3v stable. 1400MHz @ 1.3v is totally unstable, but I can just about run benchmarks with it.
My problem is lack of voltage because heat is not an issue. The card games in mid-late 40's @ 1325MHz. The highest I have seen it whilst gaming was 53deg after an hour of BF3 @ 1350MHz. The Accelero is a great cooler.
P7807 @ 1400 / 1500
Haha just ran 3DMark and it really does show just how gash my CPU is (Athlon X4 640). Scores weren't too bad for the graphics test compared to yours but then physics test kicks in and my CPU just about had a heart attackAhh well maybe some day I'll be able to afford an i5 2500k when it's about 5 years out of date
P7807 @ 1400 / 1500
I reckon I could get some 1300+ runs no fuss, but it'd mean flashing the bios, and I don't know if I can be bothered to give up Diablo 3 time to do it![]()
I know this is off topic but since I am in this thread how do you reply to a PM? From what it says I have to have messenger installed and then use internet explorer, surely that's nonsense and I can reply some other way or am I just being totally stupid (quite possible!)
Did you click on advanced mode which is on the main tab thing down the bottom left hand side (middle of 3 buttons) and then go into settings > tuning > overclock enhancements ?
