Okay, sussed the bios flash thingy and my Accelero TTII cooled Powercolor 7850 is now unlocked to 1.3v.
You need the following:-
*ASUS DCII TOP BIOS
*Latest ATIFLASH 3.95
*DOS bootable USB stick (research this yourself).
Instructions - DO AT OWN RISK!
1). Copy the ASUS BIOS and ATIFLASH onto your bootable USB stick and rename the ASUS BIOS file to "ASUS7850.ROM"
2). Change you PC BIOS so that it boots from USB stick.
3). Boot to USB Stick
4). At DOS prompt backup your existing BIOS with command "atiflash -s 0 BACKUP.ROM"
5). Flash to ASUS BIOS with command "atiflash -p -f 0 ASUS7850.ROM"
6). Wait 20 seconds or so until you are told that BIOS flash is complete.
7). Restart
8). You will need to reinstall you AMD drivers because your PC sees the new BIOS as a new card.
I have just passed Heaven at 1350MHz core / 1500MHz mem @ 1.275v. Trying for more.....
I've got the sapphire card and got it upto 1200/1475 @ 1.185v with Sapphire Trixx.
Thanks for that, think I'll be happy with the sapphire then. How is the fan noise when overclocked?
What are the temps like on the HIS cards? So long as they stay below 80deg, it doesn't really matter how many heatpipes the thing has.
My cards default voltage is 1.050v.
edit: It was 1.050v but after flashing to ASUS BIOS it now shows as 1.075v. Different partners must tweak to different levels, so voltage may have nothing to do with silicon quality.
You should see some nice performance gains over that gtx 260Welp I went and bought one. System rebuild shall commence at the weekend!
Think I'm going to send my HIS card back. I'm getting system freezes when starting up games occasionally. Both OC and stock clocks. Is the DSR 14 days from when you receive it or when you placed the order? As mine was on pre-order for over a week.
nobody having that b grade msi 7850 for £170 then?
http://www.overclockers.co.uk/showproduct.php?prodid=BG-256-MS&groupid=595&catid=683&subcat=
Looks like someone took it.![]()
yes took them all of 4 minutes, didnt even say thanks
