You have to put ASUS Tweak into 'Advanced' mode to get the option to unlock
Someone took a screenshot of where that is in the thread.
Thats a really good score there, how are you managing to get just over 51fps @ 1080 core?
Anyone any idea why max volts I can set are 1165 then?
My ASIC is 85.1% on my MSI 7850, just curious to know something i spotted in gpuz. It says my bus interface is PCI-E 3.0 x16 @ x16 1.1
Does that mean that my card is running a pci 1.1 as its downclocked to 300/150? I ran the render test by click on the ? and noticed the bus interface changed to PCI-E 3.0 x16 @ x16 2.0 with my clocks at 1050/1200
Hmm not sure bradmax57, Try the version I am on, I can go upto 1.225...ASUS GPU Tweak 2.0.6.
How do I revert back to my HIS7850 Bios?
When I used the method on Page 43, I did save my rom and atiflash called it "Backup.rom" by default.
But when I run "atiflash -p -f backup.rom" I get an error.
I have renamed "backup.rom" to "his7850.rom" and run "atiflash -p -f his7850.rom" but nothing happens.
I'm afraid that my card may meet an early death like 555BUK's.![]()
Any Takers?![]()
I was just wondering how many people are getting coil whine with this card when over clocking. My previous GPU (GTX 260) and current PSU (AX850) both had very noticeable whine when on load, and I now get the same exact whine on my 7850. I've just RMA'd the PSU and I'm really hoping that the replacement will fix the problem.
