Any idea on how to get the old versions? Google has nothing![]()
Can anyone confirm Asus Tweak letting them unlock voltage adjustment in version 1.2.1.4 when not having an Asus card?
just got my shiny new msi twin frozr 3
How are you finding the Msi thus far Wazza? I have the Msi too and found it great on stock volts upto 1100, Though starting to have crashes in heaven now that I have reached 1150, Even @ 1.20v it crashes heaven.
What are your overclocks like at the moment? In the version of ccc that I have it goes all the way to 1800 mhz and 2400 mhz on the mem clock.
..and then she just died
It was fun having the fastest 7850 on the planet for a few days, but now she is dead. It was a strange death, and she certainly wasn't stressed at the time. I foolishly attempted to install the latest GPU Tweak for the second time. The first time I tried installing it I got instant screen freezes when attempting any kind of overclock. I rolled back to 2.0.6 and all was fine. I decided to give it a second go today. Install went okay, but then I opened GPU-Z.
GPU Tweak 2.1.24 + GPU-Z = Black Screen of Death.
Upon reboot, my motherboard refuses to recognise the card (no BIOS prompt) and gets stuck at error 62. I removed the card and can boot via my 2500K's iGPU okay, so I set iGPU to Primary, reinstalled the 7850 and attempted to re-flash the BIOS. BIOS flashes fine (so card is recognised by DOS), but the 7850 just will post a display output.
Also, using iGPU as primary display allows me to get into windows with the 7850 installed. Windows recognised the HD Audio from the card but CCC cannot see it and I get driver error.
It is almost as if the firmware (something other than BIOS) has been corrupted. I have inspected the card and there is absolutely no physical damage. It was not killed by heat or overclocks because it was running stock at the time (I had just installed GPU Tweak and hadn't tweaked yet).
My initial guess is that something with my flashed ASUS TOP BIOS has clashed with my Powercolor reference card, GPU Tweak, and GPU-Z. Some code other than BIOS has been corrupted and my card is no more.
WARNING
Do not flash cards to the ASUS TOP BIOS and use GPU Tweak 2124 with it. Something in this tool seems to have killed my card!
If anyone has any ideas, please post. Now I have to roll back to my EVGA 680.
I can flash BIOS's to and from it, but it is not recognised as a primary display card by 3 different mobo. I am pretty sure that it is corrupted BIOS or firmware, but probably unwriteable areas are buggered.So it's not salvageable at all?
Unlucky![]()
A few quick questions if anyone could help![]()
1.) Gigabyte card or MSI card?
2.)Does Afterburner and Gigabyted software (trixx?) work to get these overclocks?
and...3.) whats the best stable and safest overclock past 1050mhz? (what fan speed,etc.)
thanks![]()
My MSI 7850 TF III OC arrived today and first thoughts were how small it looked. Will install tomorrow, take a few photos during the process etc and then down to business and see what it can do.![]()
