Hmmm interesting. My VTX's stock volts are 1.075V... Hopefully with a decent cooler it'll go far![]()
is that under load though?
Are your stock volts 1.21V?
Had another play, liking this card a lot
Stock volts on these cards range from 1.050 1.210v. It doesn't seem to make much difference to max overclocks as most reach 1200MHz @ 1.225v with decent cooling anyway.
I'm very tempted by the TF3 version of this card. Only question is whether it is worth spending an extra £120 on the TF3 7950?
Any thoughts?
Up the volts! I assume it is failing at 1.075v so try cranking them up.Core - 1080 FAIL
