How to overclock a 7850 past 1050MHz?
Ok so I found the advanced button but still don't see any way of tweaking GPU voltage. Also tried Sapphire Trixx. :(
So I know there is a heap of info on the various 7850's on this thread but is there any general consensus on which brand 7850 is best for over clocking? I know it will depend a lot on the individual gpu but is there any brand that has better cooling or anything that will give the best chances of higher stable clock speeds?
I've got my eye on the sapphire, msi (twin frozr 3) and the power color 7850, but am open to other brands..
Thanks in advance
My Sapphire's a beast. Running at 1230/5200 24/7 never goes over 61c even with the current high ambient temperatures here.
Heaven @1920 is in the 1500s.
msi twin frozr 3,can max ccc easily,havnt pushed further yet
Thanks in advance
They pretty much all max out CCC, but to get an uber clocker is just luck of the draw. Go with what's cheapest at the time and offers a good warranty.
just tried TRIXX tonight over ASUS utility. i really like it, except the VDDC stays constant even when the card downclocks itself. with ASUS, VDDC would drop to .8v or so when there was little load. is there a setting in TRIXX to get the same result? i would think it be a bad thing to have VDDC at it's max all the time, especially if the max is more than stock for most of us.
anyone?
there will be an empty box,tick it to allow voltage adjustment
there is no empty box....I think I'm screwed until there is a BIOS editing tool released.
My ASIC quality is 84.8% btw, stock vgpu is 1.037V which caps me out at 1070MHz. Fail
I came from a 5850...just uninstalled old drivers and installed 12.4 along with the new card. I'm at work right now, will try messing around with it more when I get home.
I am considering getting a second 7850 because of the prices at the moment, but my motherboard only supports 16x/4x for crossfire, but it is a pci-e 3 board, so would this still ruin the performance of crossfire?
So far my results for my msi tf3
Stock voltage is 1.138v and ASIC is 80%.
Currently at 1175 core and 5800mhz mem 1.145v.
Ran through heaven bench fine at that and just been gaming for a hour which was fine also. Temps hit 70c but my case has very little airflow and room is quite warm.
Gotta say the card is great. Runs so quiet and cool.
well my msi Twin Frozr IV is at 1250 core and 5520 memory, 1.254 volts and temps of 65 auto fan profile, in dirt 3 in a hot room, not bad at all.
Please resize image to a maximum 1024 pixels wide.
