How to overclock a 7850 past 1050MHz?
Been clocking abit and so far this is best ive had.
Core 1200Mhz
Mem 1375Mhz
Voltage 1.25v
Board Power +20%.
12.6 Beta Drivers.
i5-2500K @ stock
8GB DDR3 1333mhz
***Please resize image to no more than 1024 wide.***
[Damien];22043793 said:
At max catalyst settings w/ stock voltage my card runs and passes heaven fine, If I so much as bump the core up to 1100 from 1050 heaven causes the gfx driver to crash and restart. Bumping the voltage up to 1100 or even 1225 has no effect on stopping it crashing. I've tried with both the memory @ stock speeds, or at max catalyst settings (5800).
Baby steps are needed I think...
snip
I wondered why your results were so high but then you dont have tessellation enabled.
Upped the memory a bit on mine :)
MSI HD 7850 Power Edition Twin Frozr IV OC
Core 1250Mhz
Mem 1400Mhz
Voltage 1.25v
Board Power +00%.
12.6 Beta Drivers.
i5-2500K @ 4.5 Ghz
16GB DDR3 1600mhz
Mine only goes upto 1.225v too, its a shame because I know I would get at least 1250 with 1.25v.
Although My scores are a tiny bit higher than Balb0wa's. I'm talking 0.5fps.
Do you find that memory speed gives best fps?
It seems to on my card, might be different on yours. I'm just about to do a couple of benches to test it actually. Because I haven't really tested that out. I know I get grey screens at 1500mhz. I'll report back in a few minutes.
Managed to get 1250Mhz/1400Mhz to run heaven but wont go any higher on core without flashing the bios to allow more voltage.
These are what I managed to get, everything on full for all the benches with vsync off running 1200mhz core.
Crysis 2
MEM FPS1 FPS2 FPS3
1550 55.83 54.17 Crash
1525 55.83 54.05 54.02
1500 55.36 53.41 53.51
1475 55.28 53.62 53.66
1450 54.95 53.49 53.44
1425 54.45 52.86 52.77
BatmanAC
MEM FPS1 FPS2 FPS3
1475 74 74 74
1450 73 74 74
1425 72 73 73
Just Cause 2
MEM FPS1 FPS2 FPS3
1475 61.06 60.42 60.24
1450 59.85 59.73 59.96
First run is stock 920/1150, Sapphire OC edition
Second is 1100/1500 @ 1.75v
Should shed some light on the Core clock vs memory clock fps question.
With the volt that low in the safe zone I think i'll call it a day. My card isn't very core clock friendly but memory clock it seems to be okay with to pump up.
First of all Tesselation should be normal; Anisotropy should be 4X and you should run 4X Anti Aliasing.
It's the Core speed that needs to be notched up. Once you crash in heaven; up the Voltage but don't exceed the recommended threshold or whatever you consider to be a safe temperature. Also it's worth noting that people have their GPU's liquid cooled so if they get higher benchmarks, it's because they can push their cards higher than those on air coolers.
Additionally, there will come a point where the over voltage protection will kick in, so whilst you can push higher clock speeds the Heaven score will start to decrease.
The process of overclocking is an iterative process, where you gradually make changes and test to see how stable it is. You should only be making one change at a time so that you can assess if the change improves things, if it doesn't change it back and change something else. Also keep a note of your last stable settings so that you can revert to them if you reach a point where several minor increases in voltage etc makes no difference to stability.
TL;DR This is an example of how I approached overclocking.
