How to REMOVE Rain-X from a Windscreen
28 Nov 2008
Newcastle
Long story short, I put Rain-X on my windscreen thinking it would help, basically, It's worse than ever.
Ever wipe of the wipers just leaves a haze on the screen. Probably my fault, not applying it properly or whatever.
But how do I get this **** off? This is how I imagine Stevie Wonder drives! It's horrible!
From the Rain X website . . . "Rain‑X® Extreme Clean is the best product to use to remove Rain‑X® from a glass surface."
After the experience with this insidious liquid, i wish to avoid their products.
Warm water & vinegar & use a newspaper as the cloth.
also,
inb4Sand Paper as I've seen mentioned on my internet searches.
I'm old mate & back in the dark ages the best thing in the world to clean glass with was warm water & vinegar & use a newspaper as the cloth, Still works today & is great to clean your windscreen & wiper blades with.
Bonus is it's cheap & you have all 3 items already.
Fairy Liquid?
Already tried that! with multiple washes, mild sponge attacks and letting it dwell. As well as blasting the bejesus out of the shield with a pressure washer.and trying AutoGlym Fast glass.
Guess its worth a go! The internet seems to agree with you.
Are you going to apply any other type after you remove btw? I'm curious to see someone use Gtech G1, was looking into buying it (especially due to weather now).
I tried Rain X recently and thought it worked brilliantly, though it didn't seem to last very long. I suspect it may depend on how carefully it's applied, since it's not as simple as slapping it on and giving a quick wipe.
