I'd be inclined to keep what you have, but yes, 750 is enough, though the 850 is just a tenner more.750 & 850 are enough?
My current one that is apparently about to explode is 1200W Platinum, has the technology improved in the last 8 years that a 750W PSU will suffice on 8 year newer components?
Thank you.
I'm inclined to keep what I have too and didn't even consider getting a new PSU until Quartz mentioned it might kill all my other components.I'd be inclined to keep what you have, but yes, 750 is enough, though the 850 is just a tenner more.
More detailed answer: the 4070 Ti Super is around 300 watts and the 7800X3D is between 50-100 (depends on the game). If you allow 50 for your other parts then that puts you at 450, but that's leaving some headroom as you can see in this review which includes whole system power numbers with a 7800X3D:
Well that's a thoroughly depressing video in regards to my recently aquired 4070Ti Super, it seems to be quite a bit below or very similar to the 7900XT which is quite a bit cheaper as well.I'd be inclined to keep what you have, but yes, 750 is enough, though the 850 is just a tenner more.
You were supposed to just be looking at the power figures!Well that's a thoroughly depressing video in regards to my recently aquired 4070Ti Super, it seems to be quite a bit below or very similar to the 7900XT which is quite a bit cheaper as well.
I'm seriously considering returning the 4070Ti Super now, I thought it was supposed to be quite a bit better than the 7900XT and not far off the 7900XTX![]()
Sorry about thatYou were supposed to just be looking at the power figures!![]()
I would send it back, personally. The AMD option is better.Sorry about that
I've watched a few other comparison videos and the 7900XT really does seem the better card in regards to a few of the games I mentioned in my original post like Baldur's Gate 3 and Starfield, not sure which is better for World of Warcraft as no one really tests that one.
I have 4 weeks to be able to return the 4070Ti Super so I'll do some further research on VR and Flight Sims, though to be honest I rarely play Microsoft Flight Simulator much these days so I won't use that as a deciding factor, Warcraft is the main one.
I might even be able to stretch to one of the cheaper 7900XTX's i.e the ones under £900.
Thanks again.
There was a lot of noise about Warcraft having issues with AMD awhile back, many threads on reddit. It might be fixed by now, but I'd have a look into it.Warcraft is the main one.
Is this for World of Warcraft or just in general?I would send it back, personally. The AMD option is better.
I will definitely look into it.There was a lot of noise about Warcraft having issues with AMD awhile back, many threads on reddit. It might be fixed by now, but I'd have a look into it.
AMD is good value but there are a couple of caveats to buying them.I will definitely look into it.
I was reading a few sites last night that did seem to allude that AMD did sort out the issues with both Warcraft and VR.
Warcraft also uses FSR 1 on one of their expansions but to my knowledge have never used DLSS but then it hasn't used FSR 2 or 3 either.
Thanks again.
Thank you.AMD is good value but there are a couple of caveats to buying them.
Their drivers often mature with age and are often very buggy at release - it’s been like that for ages with AMD.
AMD doesn’t do Ray Tracing as well as Nvidia does but having had a 3080 and tried RT, I can’t say that it’s a deal breaker for me personally and I prefer the pure rasterisation performance.
AMD is usually better value with more VRAM which means your GPU should mature better.
Nvidia is super stingy with their VRAM and 8gigs just isn’t enough these days.
At a minimum, you want 10gigs of VRAM and ideally you’d be looking at 12 or even 16gigs.
I would also consider Intel GPUs if they are well priced, they seem to have had major driver improvements too and if they are on sale, they can be excellent value.
It really depends on your preferences tho.
In ye olden days benchmarks only had maximum FPS, which was kind of meaningful about their performance, but it didn't really give you a clear idea of how they performed.a lot of the statistics they mention I don't understand like 1% lows.
