My Rockhopper has a lockout on the front forks that reduces the travel to about 20mm. This is perfectly adequate for road and most towpath use, while still having the option of proper suspension if the going does get rough.
The best of both worlds really
I'm currently using a pair of totally smooth tyres and have only fallen off once this winter, on ice, and i'd have come off on standard tyres too. You do suffer a bit on very muddy towpaths, but on hard surfaces you lose no traction or grip and gain about 5 minuites in a half hour journey.
Re the bike you want, i like the Specialized range and the Hardrock fits in to your price range nicely, or the Rockhopper for a bit more. Both are highly upgradeable and will last you for years, the hardrock is slightly heavier. Both are fitted out to a very high standard.
Another upgrade you may want to think about for the future are disc brakes which are not the gimmicks I once thought they were! I wouldn't be without them now, i don't know if my riding style has changed through knowing i can stop in half the distance but they have saved me a couple of near misses on the road. With the number of idiots driving these days you need to be able to stop quickly, and brakes are not something to skimp on
