I need an SRT guide
7 May 2011
I've got Windows 7 on a SATA drive and just bought a 64GB M4.
I'd like to partition the M4 into two - to reinstall Windows and to use as a cache for other files e.g. games.
Is this possible/ sensible?
Where can I find a definitive guide? I've searched but not found one.
thanks
Blonkster
28 Dec 2009
Wales
This is a thread on here some where with a step by step by someone who has done this. Can't find it right now though, worth having a look for mate!
25 Jun 2011
Aberdeen
I looked into this a while back as an option, I believe it was something like so:
1. Install windows to a seperate drive, setup your partition on the SSD for both OS and SRT.
2. Install/Setp SRT on the partition you require
3. Reinstall windows, this time selecting the left over partition on the SSD.
This is from memory btw, but I did read it by a member on here, possibly the same post welshdragon is thinking of.
This method is required seemingly due to SRT not actually being on a visible (accessible) drive once installed, so once windows is installed the SRT partition exisits already without making your SSD disappear from windows.
OP
7 May 2011
Had a very bad day trying to sort this out!
I cannot get Win 7 install to see the SSD if ANY other drives are connected. I also have to insert a usb stick with the intel raid drivers on to see the SSD, and can then install.
However. when I connect my HDDs it seems to try ot boot from the SSD but boots from the HDD.
If I then disconnect the HHD and reboot it fails saying 'reboot and select proper boot device etc.'
WTF? is going on? Could by SSD be faulty?
HELP!!!
