I need Help with a first build
Yes the 660ti is good. Look up reviews, but it's in the ballpark of the 7950 / 7870. Usually, NVidia's are a little bit more expensive than the AMD equivalent for the performance. I suppose you pay for the badge, but they are good cards, especially the new Kepler 6xxx series.
The KFA2 EX OC 660ti looks quite good. I'd read reviews before deciding. The difference between a bunch of cards sharing the same GPU processor is the noise level and temperatures. Overclocking can be a bit better too.
YOUR BASKET
1 x KFA2 GeForce GTX 660TI EX OC 3072MB GDDR5 PCI-Express Graphics Card £259.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £184.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x OCZ ZT 550W '80 Plus Bronze' Modular Power Supply £63.98
1 x BitFenix Outlaw Gaming Case - Black £39.95
1 x **B Grade** Cooler Master Hyper 612S CPU Cooler (Socket LGA1366/1156/1155/775/AM3/AM2+/AM2) £32.99
1 x OcUK Value 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £26.99
Total : £702.38 (includes shipping : £11.25).
This Psu is sufficient for your needs. Had to drop the fan to keep within budget. Also check with OCUK about the "B" grade cooler. Find out what the condition is and ask them to knock something off the price, seeing as they are asking the same as a new one.
The fan you can always get later, if you think you need better airflow.
YOUR BASKET
1 x MSI HD 7970 Lightning 3072MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** £383.99
1 x "Primo 6000i" Intel Pentium G620 2.60GHz DDR3 Dual Core System £202.98
1 x System 12 Months Standard Warranty £0
1 x Microsoft Office Starter Edition £1.51
1 x TeamGroup Elite 4GB (1x4GB) DDR3 PC3-12800C11 1600MHz Single Channel Module (TED34GM1600C1101) £19.99
1 x No Hard Drive Upgrade £0
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x No Graphics Card Upgrade £0
Total : £692.46 (includes shipping : FREE).
YOUR BASKET
I would not recommended the OP or even my worst enemy try that GFX card on that PSU.
Kaboom.
Is that common - specifically does it apply to Brunel or Open University? If so then that could save me a few £ too. (Trying to sort a pc for son to take to Uni).
Yeah its pretty common if your uni is enroled with the websites that do this sort of offer then they should do it. you do need to have a student id number though so it might be worth waiting until your son has his id before attempting to get the software.
