Have you checked all your fans are the right direction, sucking in at the front and blowing out the back. And that is WAY too much thermal paste, you only need half a small pea size.
Dear ******
Sir that isn't overheating, mine reaches 85 degrees at stock.
Regards,
Not the reply I was expecting via webnote
Guess I'll have to ring them. I'm going to feel awfully geeky sitting at my desk talking about cpu temps....
So you have the CPU fan going to a MOLEX connector and the 3pin connector to motherboard to report RPM's?
Just had a look at your cpu pic zoomed in. It looks more like a cream cake.
You only need a bit of tim approx the same size as this ( - ).
Check that the bracket is mounted correctly and when you mount the cooler tighten each screw 1 full turn then do the other one until tight. Fire up and check temps.
This may be obvious, but, you have checked that the CPU fan actually spins haven't you?
I only ask as this wouldn't be the first time I've encountered a fan splitter cable that didn't actually work!
I think I have 1 of the Akasa PWM splitter cables where it seems that one fan is always on 100%. I've had other splitter cables were none of the fans work.
Maybe yours is somewhere in-between those 2 extremes?
Well, ok smack in-between stuck on full speed and not working at all would probably be working perfectly, but you know what I mean...
I dont think its the best cooler of overclocking tbh, However I thought it would be fine for ~4.5GHz.
If it was a heatsink or contact issue surely his idle temps would be effected too?
It could be – but from his posts he seems to have eliminated those.That suggests to me either a warm case with bad air flow or the fan on the heat sink isn't spinning fast enough?
The Gelid is a great cooler i've fitted a couple onto friends builds and it's been more than capable of keeping clocked Ks frosty.
Personally, if the fan is operating properly and you've tried smaller amounts of TIM, then it's probably a contact issue between the HS and the CPU.
It may be that the bracket, for whatever reason, isn't creating enough pressure bewteen the 2 surfaces so that heat transference isn't as efficient as it should be.
I would contact Gelid - they will probably send you out new fixings gratis if you link them to this thread or even send you out a replacement unit - as your results indicate a problem rather than a poor pruduct.
