- 12 Jun 2011
also in the dram is there any setting i can change on the ram to improve that?
well after 1 min it dropped from 4700 down to 4000 its now at 3900 core voltage 1.304v its about 30 mins in .
maybe this is the reason cant be oc past 4ghz????? dont see why not tho
You need to raise the core current limit to about 250, that's what's holding you back
just raised the limit to 250 shows as x47 multiplier when i run prime 95 drops again to x41 / x40 when i stop the stress test raised back up to 47000mhz
i was hopefull that would work, it has improved it though so you really need to find out what the max you can go is on the core limit coz it sounds like if you bump it up more it will fix your problem
its still dropped down to x39![]()
ill give that a try also f-stream now saying my m/b temp is -1degree C
before was about 35c
even with my chip a 5GHz it still doesnt hit 7.9? lolz
Only one system has ever scored 7.9 on WEI
specs are :
CPU
Dual 6-core X5680's
Motherboard
SR-2 (chilled water cooled)
Memory
G.Skill 48GB
Server hardware maxed out it seems. So your SB chip is still doing well![]()
wowzers 48gb ram!!! dual 6 core!!! haha, i am very pleased with my system
