- 13 Jul 2010
ok im currently using the asus p6t oc palm edition
Ok next thing i would say is plug pump into the "PWR_FAN" header on mobo.
Run HWmonitor then and post a screenie plz.
)Seems to be within normal range but on my kids pc its running at 1500 on a P6t.
Did you run Cpuz while stressing to see what volts your running at?
Also does your mobo need a bios flash do run your cpu properly?
I know my evga does.
Silly question but are both fans facing the same direction (ie label on right side of each)?
As i seen seen people face the fans blowing at each other. (no offence meant)
Oh then its not the cooler.the thing is tho im was getting around the same temps with a Noctua NH-U12P that's the main reason i got the Corsair h50 plus to set-up a second i7 system
)Oh then its not the cooler.
How much thermal paste did you apply and did you clean old of before putting new on?
When you flashed the bios did you load defaults after it?
Either way try taking battery out of mobo for about tens mins and load defaults.
If that doesn't help it must be either a dodgy cpu or mobo (unless your in the sahara or your case is a closed box)
Are you 100% sure that all the "teeth" (for lack of a better word) on the cpu cage thing are sat insdide the grooves on the H50 cpu block?
I had a problem with temps just like you are having and realised that this was the reason. But, my problems with temps was when the CPU was OC'd to 3.8ghz, not stock.
My idle temps now are 40-50 and max load is 70-75. I have been tempted to get a decent air cooler to compare. But I really can't be bothered![]()
so far stressing for just under 20 minutes
Running with the stock cooler @ stock settings my 930 tops out @ 73c.....
I guess this is normal?
Hi guys im currently running an i7 930 at stock speed and the temps are running a little high.
my current cooler is an Corsair H50 in push/pull configuration
room temp is around 24-25c
thanks
