I'd been saving for an i7 set up for a while (haven't we all) so being as I was going to be taking it all apart I thought i'd go the whole hog.
The Skeleton has always strck me as appearing very "industrial" in its appearance, looking like some sort of turbine cooling device that ought to have a big yellow warning sign on it. It's this "warning" theme that led to the colour scheme of the build.
I started the mod about a month ago, working at weekends and in the evening. It's just about finished now, with some spraying and assembly yet to happen but I thought i'd post what i'd done so far.
I should perhaps point out that I've never built a rig from scratch before although I have transplanted my old rig into the skeleton case. Neither have I ever modded anything before beyond adding a few ccfls or braiding a cable or two. I've learned quite a bit along the way (especially about spray painting) but as a beginner I'd appreciate any hints and tips as to how I could have done things differently.
here's what it looked like as I took it all apart
Stage 1
Cut the cowling to accomodate fenrir cooler.
there's 157mm of clearance between the CPU and the underside of the "big boy" fan. The fenrir is 156mm in height. so I had to be fairly accurate with my cutting, but first I had to buy a dremmel (been looking for an excuse for a while
Lesson learned No 1 When you cut plastic with a dremmel it melts!!!
I then took the whole thing to bits and set about masking ready for spraying. Anybody who's ever masked a fan will know what a pain in the rectum it is.
never really spray painted before, apart from the odd bus shelter in my youth so very steep learning curve
Lesson learned No2 Dust is the enemy
Lesson learned No3 sand between coats for a better finish
lesson learned No4 don't be tempted to touch it between coats as grease from your fingers from handling the job between coats causes the next coat to crackle when it dries in the areas you have touched it. You then have to sand it all back to the plastic base and start again.
Continuing the black and yellow theme I re braided all my cables (very theraputic). I also quite like the look achieved when putting anti kink coil over braided cable, I know it's not what it's for, but like I say I happen to like the look.
I also modded a Corsair Airflow fan as part of the build
http://forums.overclockers.co.uk/showthread.php?p=14970908#post14970908
So that's pretty much where I'm up to now. Just got to get it all back together and working!!!
