was it plastic primer which worked for you?
thanks
used grey plastic primer from the big orange car parts place.
Now the weathers turned a bit cooler i'm warming all paints for a few mins in hot water prior to spraying as this helps the paint flow more evenly from the cans. I tried the plastikote grey primer at an early stage in the mod when I was testing paints and didn't find it nearly as good, but that was just my own personal experience, i'm by no means an expert.
Yes it can cause problems. You could end up with a cloudy appearance in the paint, plus it will take longer to dry. Shouldn't affect the primer too much apart from taking longer to dry, but it will be more noticable on the top coat.yeah i have a few cans of halfords plastic primer around, spraying in the cold does it affect the paintwork if my metal is cold/?
thanks
You can still encounter "bloom" problems when going from warm to cold. My understanding is that bloom is essentially caused by changes of temp causing microscopic condensation within the paint as it dries, I think it mainly effects 2pack paint but can happen when using cans.
Advice would be to spray in the warm if you can, but if not then in the cold if you have nowhere else to do it, but warm the can a little first to aid flow. It's not too cold at the moment, but it will take an age to dry.
i've been undercoating and top coating today and it's all been fine
I painted (sprayed) an MG Midget one afternoon. After the paint had cured for a couple of hours we pushed it out of the garage so we could get the next car in. A few hours later I checked on the MG and it had bloomed on every panel! Looked horrible!
That was quite a few years ago though (just reminded myself how old I am!). We never did it again![]()
are you doing this indoor or outdoor?
(ventilated)
I'm doing all my painting indoor as I think the dust risk is less there. you could spray out door but it is getting cooler these days and the risk of bugs and stuff landing on the job is greater than indoor.
Be warned if using a shed or garage, the dust the spraypaint generates will land on everything. You can get round it by setting yourself up a little spray tent by using polythene sheeting, but if you do, please be very aware of the danger from the fumes. If you're not to bothered and it's all your crap that the paint spray dust is landing on then no need to bother.
Shouild have a few more pics tomorrow, as will be top coating several things.
Also planning on taking my switch box apart and trying to work out how to wire up the new LED toggle switches.
