- 22 Oct 2012
- The Moon
I like the price of that monitor but as I'm using a 2070 its not good for me
Tried Shadow of the Tomb Raider and got about 60-70ish with my 1080Ti
Would you suggest a replacement to see if it's any better? When not photographing it, doesn't seem so bad, but it's worse than my previous screen. There is a concern the replacement could be worse
If you aren't happy with it and it bothers you in normal usage with a reasonable brightness then I would get a replacement.
Just to check something. The highest refresh rate my monitor is currently showing at 3440x1440 is 75hz. I'm using an older GPU at the moment which only has DP1.2, so is it correct that this is limiting the options shown. In other words, I'm not missing out on being able to set the refresh rate higher for desktop usage, e.g. 100hz? I completely accept I won't be gaming at those rates!!
You should be able to get 100Hz @ 8Bit with DP1.2 I would have thought. It can do 144Hz at normal 1440p, so 100Hz at ultrawide should be possible
Another review:
https://www.kitguru.net/peripherals...3461wqsu-b1-34in-144hz-gaming-monitor-review/
Still thoroughly enjoying mine. Read that apparently, the latest firmware has fixed the screen waking up/half screen glitch issue too so it should be relatively save now to get one.....
Shame we can't update monitors firmware by ourselves like we can with TVs, odd why we can't!?
Would a 5700XT be good enough to have decent frame rates with this monitor? Only have a 4GB 5500XT at the minute so looking at my future upgrade plans.
To be honest, I'm actually a bit disappointed with this monitor (ignoring the issues I've had with it). I think the best summary I can give of it is that it's image is "dull". Compared to my Electriq 27" 95 Hz monitor (Pixio 275h), the colours don't pop like most IPS monitors I've used and even considering it's ultrawide, it costs £400 compared to the £150 of the former. I suppose some people would like this because muted colours are more accurate; the white's aren't particularly bright in my opinion though.
It's vastly superior to VA UW monitors I've tried though - there's very little ghosting as far as I can tell so it is a good gaming monitor; I just think it's not the one for me.
Have you calibrated it? Only reason I ask is that I felt the same initially so colour calibrated it in windows which for me made a big difference. Also can add digital vibrancy through nv control panel and the colours pop more if that's what you're used to.
I have the electriq 32" IPS and the colour popped more, although I had to mute it by decreasing vibrancy.
