You can still sell your old PSU to raise some fundage![]()
Can someone clear this up, as this thread has been a little confusing.
On his psu there is
1 pcie- 6 pin
1 pcie- 6+2 pin
On the adapters you get with the lightning there is a black wire which loops into another pin, i am presuming this is to give extra power. Otherwise why would they place 2 of said adapters in the box.
Will post a picture if it helps.
And if it were to work, and you got one, i'd advise not to overclock it until you got a replacement psu.
I'd have gone for a modular psu personally - don't think your case has cable management so could be a little messy.
If you now gone 7950 you could have stuck with your existing psu as that msi 7950 tf3 has one 8pin and one 6pin connection.
Fully modular = way more money
OP has already had to cut down from a 7970 lightning to a 7950 due to needing a psu.
If he went fully modular he would be getting a 8800 gtx or something
This is the best psu there is for the money mate.I have a fully modular and it cost £210 (its xfx aswell)
He doesnt have one 8 pin!!
he has one 8 pin plug with 6 cables coming out of it. That is not an 8 pin supply rated at 150 watts.
With the new psu now OP is future proof. At least for the time being anyway![]()
Thanks cammy. so now that the new psu is coming. I'll have the proper cables for the msi tfiii 7950. Does the msi7950 have 1 6pin to 8pin in the card box? or is does the psu have the cables for this one I'm getting?
This 7950 does 1 6pin and 1 8pin.
Thanks again my friend![]()
So do you mean that 6+2 pin cable only has 6 pins going into the psu?
Yes mate thats exactly what that ocz psu had. ocz should hang there heads in shame.
No wonder the cheaper ocz psu keep going POP
Bit over the top.
The difference between the 7970 lightning and the TF 7950 is £110,
Could easily get a decent modular psu for less than that, about £85.
Doesn't need to be fully modular, just saves having tonnes of sata connectors and stuff blocking airflow. Even something like this which is practically the same price: http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-SS&groupid=701&catid=123&subcat=
I only have maybe £65 to £70 to spend If I have too?
Wouldn't think a lightning would be needing more than 550 though, i'd rather have a modular with a little less power tbh.
Although like you listed i'd rather spend another £30 for a higher power modular, psus are things you rarely ever need to upgrade especially if they are good quality.
Just if I had £380 total to spend and I needed a new psu i'd get the best one available to me. Where everyone differs I guess.
