I'm not sure I agree, depending on your stroke rate, one pull cover 5 to 10 metres so it's all about timing. I haven't used a concept 2 for about 3 years but 1.29.3 was my 500m PB with 2.5k n 7.24 iirc. I'd be way off that now...What damper settings are people using? I use to float around 6 to 7
Was going good till the 5th and started to fail at the end. Heart rate going too high and body stopping working lol.
Still, its a good starting point. Its annoying that you have 1:45 on the screen, but in reality its a bit higher as you don't see the decimal point.
Whats does the r998 mean?
Oops, thought I was going slow
If I up the stroke rate, I'll lower the 1:45? I was just trying to hold 1:45.
If you want to practice this simply row without the straps - it will be hard to start but you will get the hang of it and your glutes will hurt after about 3k as you engage them in a way you never have before! I recommend this as it will make your more efficient when you put the straps back on and should lead to decent improvements.
I was doing ok strapless until I almost fell off the back after 5 mins, lol.
So I strapped my feet in and carried on. I was producing more power with my feet strapped in because I will push with my legs as I'm not scared of falling off the back.
Guess its just practice.
Need to get a new plan in asap.
) with a 1:52.4 split. Noticeably different from the last one in that I didn't struggle aerobically at all, just struggled from lactate build up, but that was to be expected as we've had a heavy last two weeks of training and I didn't bi-carb load beforehand.
Street;30464597 said:I'm a massive fan of the Pete Plan! I've been working my way through the Beginner Pete Plan with an aim to start the Pete Plan proper when I'm done. The BPP is a 24 week plan with 3 days and 2 optional days per week and has a nice mix of SS, speed intervals and endurance intervals. I'm up to week 23 and my times have improved massively since I started and I generally do all five sessions a week. The training thread on the Concept2 forums is good too as there are a group of people doing the PP/BPP so you can get a bit competitive with times.
Street;30485903 said:Good work! Those speed intervals get tough, towards the end you're doing 8x500m. The 2min rest seems ages when you start but when you're blowing out your arse on the 6th rep it feels like nothing!![]()
Street;30485903 said:I think the aim is to do a pace you think you can manage for all 6, do it for 5, then go all out on the 6th. Then the next time you do that session, do the pace you averaged for this session for all but the last rep again.
Andyt_uk;30486240 said:My splits were;
1:49.6 @ 28s/m
1:49.0 @ 29s/m
1:44.5 @ 31s/m
1:48.4 @ 31s/m
1:47.9 @ 31s/m
1:53.8 @ 31s/m
Fairly happy with those for now seeing as its some time this I've done any real exercise, think I'm going to enjoy the plan! Another 5k planned for tomorrow hopefully.
rodders;30487704 said:Did 6x500m all just under 1:45. Not and 100% dying at the end, should have done another one.
Need to go for that sub 7 2km now.
