- 22 Oct 2012
Again, suggest you chuck another 140mm or 120mm below your current intake fan and your GPU temps should drop noticeably.
LOL convection???
OK just spent an hour or so fitting a 100mm fan to the rear of the case by the CPU cooler. (things take much longer now)
and I had a bit of cable management as well... quite chuffed TBH
Anyway
I have re-run the Heaven benchmark. 30 mins then benchmark and my CPU temps have dropped to mid to high 50's... awesome....
GPU is still 83 but I am now OK with that being it's baseline, seeing that I am using the card to manage the fan speed, it still is quieter than the case..
Cheers all
Come on! pics or it didnt happen![]()
Your Heaven benchmark is better than my little ITX system which has a GTX 980.
Its a 4770k at 4.5ghz.
Stock palit jetstream speeds.
Have you thought about adding an exhaust fan to your side panel, if it permits?
I used to have 2 fans blowing air in to the side onto the vid card, but switched it have them suck air out, it was a night and day difference.
I have a Powercolor PCS+ 290x OC, and it's @ 71 degrees max at 40% fan speed, which is silent.
Otherwise its a great card...
My OC has given me a 10% increase over stock on both heaven and fire strike, so I can't complain...
