- 2 Jan 2012
- UK.
What voltage are you putting through for 4.6GHz?
CPU ~ 1.325V.
VRING ~ 1.2V.
CPU ~ 1.325V.
VRING ~ 1.2V.
My HW-E is very poor clocker and cant do 125 strap no matter what, so im stuck with 2666mhz on memory at lest i spend whole weekend on getting timings down as much as possible.
Only reason for me to jump in to BW-E is that I lost silicon lottery :/
Maybe they will clock better ?? Can only hopeIf it would do 4.6@125 strap i would pay for an upgrade.
Atm my setup in single thread is just TINY bit faster than my sandy@5ghz was![]()
If its like standard haswell on Asus X99 boards, ring is known as cache.
Why would he be happy with 4.5 when he has tasted 5.0?
He tasted 5.0Ghz on a Sandy Bridge quad core chip. The six core 5820k @ 4.5Ghz obliterates the Sandy Bridge chip clocked at 5.0Ghz
Isn't HW-E quad channel,so why are people worried about memory overclocks??
Yeah I would say about £500, depending on how well the mid tier £500 new chip performs. Hopefully get about £300 - £350 for my 5930K when it's time to switch to Broadwell.
Out of interest will Intel be doing a X99 chipset refresh for Broadwell-E.
Care to elaborate? Are you saying people buying enthusiasts platforms shouldn't want to push memory frequency / latency? Don't understand...
Personally for me Broadwell-e will probably not be worth upgrading to and neither will Skylake-e, I think 10% or less faster is not worth replacing the whole motherboard & cpu for, to me at least.I've already had x99 some months now and the upgrade was worth it over my old x58 system. The board has all the new technologies that will be needed for some years yet.
I could probably see me keeping this x99 setup for 3 years minimum no problem, even then I doubt there will be CPU's approaching 20% faster than the current ones.
Next for me will be something that is actually a large noticeable increase in performance, and at this rate that could very well be 4-5 years from now. In the meantime I think I will just buy/sell a new high end GPU every 1-2 years.
I guess that's the good thing about buying upper mid-end/high end hardware, it certainly lasts a long time if you want it to, at least these days it does anyway![]()
Umm,the whole point of increasing clockspeed is to improve memory bandwidth,so even if X99 chips can only run RAM at a lower clockspeed than say the socket 1151 ones when using DDR4,the latter is still going to have less available bandwidth anyway since its only dual channel. Plus the whole X99 platform can simply run far more RAM too and AFAIK Skylake does not support ECC Ram for consumer versions,whereas Haswell-E does and probably Broadwell-E,so it makes the memory controller more complex,hence no wonder Skylake can be pushed higher.
Well at least there is an upgrade path for X99 MB you never know with Intel. I just hope the overall quality of Broadwell-E is more consistent you could pick up some really poor clockers with Haswell-E.
He said the latter meaning the 1151 chips.lol what the hell are you talking about. Broadwell-E isn't dual channel, and last time I checked higher frequencies and lower latency are always a bonus...
