I've had a 4 year break from the CPU forum.
Glad to see the same people arguing about the same tripe![]()
Has it been that long since spectre and meltdown?
Yeah, that would make sense. There's a rumour they even fired their validation team, which if true, clearly worked out great for them!
I can't easily as I don't have ready access - but here is an example of one from Buildzoid https://youtu.be/yYfBxmBfq7k?t=1320
I've seen it still happening on some cores, on some CPUs, when under full amperage loads.
Plus at least a couple reports of 14900k hitting just under 1.7v while sitting in the BIOS lmao
Der Bauer has further input on this if you have not seen it:
This could be a Big Problem for Intel
Gamers Nexus Videos:https://www.youtube.com/watch?v=gTeubeCIwRwhttps://www.youtube.com/watch?v=OVdmK1UGzGsIntel Statement:https://www.reddit.com/r/intel/comm...youtu.be
Certain individuals in here should watch it to better understand how voltage and current are intrinsically related.
I guess he is saying that some people on here don't understand how voltage and current are intrinsically related and might be educated if they watch that video.Your point being?
My degree included sections on digital and analogue electronics, but I reckon I fall into "some people" as well.
Edit: Without any Googling, I think volts are how fast the current is pushed and current is how much is being pushed. I liken it to a tap in your house vs mains pressure out on the road. Like I say though, this isn't my area of skill at all.![]()
My guess is some CPUs can be saved if they act now and fix the high voltage spikes but those that have been used for too long or are at the lower end of the "binning" spectrum will need to be replaced.
How you can figure out which is which will be the interesting point and this could have major consequences for the future retail value of all systems with 13th and 14th gen CPUs.
That American System Integrator (SI) whose incoming QA was failing such a huge percentage is the answer:My guess is some CPUs can be saved if they act now and fix the high voltage spikes but those that have been used for too long or are at the lower end of the "binning" spectrum will need to be replaced.
Anyone doing volume is unlikely to spend days testing CPUs (yes they could do so in parallel but how many test rigs would they need?), therefore they probably have testing software.
UE5 is all very well, but what this needs is a tool you run and a few minutes later it tells you yah or nay.
I wouldn't surprised if Intel have such a program. And that's what they should to regain some trust:
1. Have this tool available on a new web page.
2. Tool says nay, please enter your details to start an RMA.
lets just image that they do need to replace them, what are they going to replace them with? more of the same?This is in context to how component failure happens - which is principally related to current and power dissipation, but is a bit more complicated than simply voltage goes up = current goes up because you also get constant power load situations around things like voltage regulators and control/feedback loops, etc. where lower voltage = higher current and in droop situations can result in current outside of spec.
One of the problems, though not sure if the fundamental issue here, seems to be a bug in the microcode resulting in excess voltage incompatible with the thermal situation, which potentially also violates current and power regulation. What isn't clear is whether the CPUs actually need that excess voltage or not - one situation is an easy fix which may or may not involve a small performance drop, the other means Intel is going to have to replace a lot of CPUs (as some won't be able to meet spec even at a small performance drop).
there was a report somewhere from Minecraft server provider stating on 13 and 14th gen intel cpus, there was 100% failure rate or something to that effect. you are right we don't know the scale, but that doesnt matter really does it? why would scale ever matter to the point of replacement. still doesnt change the fact that people are and will be affected and so my point still stands, what do they replace them with? more of the same? cpu development is done years in advance and so its not like they can just pull the next gen of the pipeline, its likely not even made yet. still going through testing or whateverWe don't yet even know the scale of the issue and/or whether it can be mitigated at software (microcode) level or not so a bit of an open question.
I would say maybe Bartlett CPUs but they seem awhile off yet and an assumption they aren't impacted, though Intel appear to have made a change in direction there possibly indicating they were aware of something...
there was a report somewhere from Minecraft server provider stating on 13 and 14th gen intel cpus, there was 100% failure rate or something to that effect. you are right we don't know the scale, but that doesnt matter really does it? why would scale ever matter to the point of replacement. still doesnt change the fact that people are and will be affected and so my point still stands, what do they replace them with? more of the same? cpu development is done years in advance and so its not like they can just pull the next gen of the pipeline, its likely not even made yet. sitll going through testing or whatever
