People need to take advantage of the situation and sell up… no point holding a ticking time bomb!You’d be crazy to buy one now surely or completely out of the loop?
You do, I probably would but does everybody?People need to know if their CPU is failing because of this issue, an actual stability issue or due to configuration or software error, etc. there is also no clarity right now if every one of these CPUs eventually prematurely fails or whether a subset are vulnerable and so on.
If someone has been sold a product that fails and is known to fail then IMHO most people will want it sorted. Why it failed is secondary as that will not fix / sort out their problem.
(and they will probably judge that company / brand in the process)
Exactly what I thought. He seems to be the only one really trying to inform us of the true extent of this issue. Others blaming motherboards etc is just misdirection and plain wrong at this point.It’s a great vid from Gamer’s Nexus. Good to see it documented and unraveled.
Yes because for example if it is a software crash they could go through a lot of hassle and end up at square one.
At this rate I'm not even sure that will save them, given the apparent rate of failure of plain old servers running these chips I can imagine they are running anything except intel defaults in order to keep power costs down. I guess we will find out soon when people start getting some lab analysis back.Right, to stop it from happening motherboard vendors would need to run lower power settings while at the same time Intel are advising them to use higher power settings because performance bar charts and somehow this is the fault of motherboards.
Here is a solution, 125 watts out of the box, as advertised by Intel, anything over that is clearly cited as unlocked overclocking. NEVER GOING TO HAPPEN, but its still the fault of motherboards.
If it is sponsored content, or fear of freebies from Intel in the future then IMO it is more than "just misdirection" though.Exactly what I thought. He seems to be the only one really trying to inform us of the true extent of this issue. Others blaming motherboards etc is just misdirection and plain wrong at this point.
Afaik the overvolting microcode bug is not connected to power draw, Intel have said that any 13th-14th CPUs are potentially affected, even CPUs that rarely exceed 65 watts (like the 13400) and don't have TVB (Intel denied the initial reports that the bug was limited to TVB and only the 13900/14900 CPUs have it). My understanding is that they can be given excessive (degrading) voltage even at idle.At this rate I'm not even sure that will save them, given the apparent rate of failure of plain old servers running these chips I can imagine they are running anything except intel defaults in order to keep power costs down. I guess we will find out soon when people start getting some lab analysis back.
Yes so hardly motherboard vendors issue. Although I guess intel want too spin it that wayAfaik the overvolting microcode bug is not connected to power draw, Intel have said that any 13th-14th CPUs are potentially affected, even CPUs that rarely exceed 65 watts (like the 13400) and don't have TVB (Intel denied the initial reports that the bug was limited to TVB and only the 13900/14900 CPUs have it). My understanding is that they can be given excessive (degrading) voltage even at idle.
So Intel should come clean and say SOME CPUs (who knows how many) will fail now or at some point in the future and it could be yours.Yes because for example if it is a software crash they could go through a lot of hassle and end up at square one.
EDIT: Or another scenario if someone is seeing errors but it is down to faulty RAM they might not work that out initially causing hassle later sorting the RAM if that was the cause in their case but they assumed it was the Intel issue causing the crashes.
Not software
Not ram
Not M/B
our CPU!
Job done!
Yeah, disclosed issue number 1 (overvolting microcode) is totally out of their control, so is disclosed issue number 2 (a manufacturing fault). Which makes sense, since CPUs can fail/show instability even when not used (i.e. out of the box), or only modestly used. Using very conservative settings might push the problems out further into the future, or temporarily alleviate them, but it doesn't fix it.Yes so hardly motherboard vendors issue. Although I guess intel want too spin it that way
As many current Intel users won't be changeing to AMD will they instead decide not to upgrade. This will depress CPU sales and obviously sales / profits of retailers. This mess has huge implications over a wide area.
