Intel Smart Response Technology Questions
its just like a giant ram stick,only regularly used programs or data gets copied onto the ssd to speed up read/write,if its crashes youll only lose whats on the ssd itself,you programs and data will still be on your original hdd,you might lose temporary files like passwords ect but thats about it,i never lost anything while i used it
All up and running that was easy lol
Run a benchmark with HDD by itself and the two runs with HDD+SSD you think the number are good?
Am already noticing some speed :) I went with the Corsair GT 60GB
Yeah switch off caching just incase,it will write what's stored in the ssd to your hdd,plug both hdd and ssd onto Intel sata3 ports and re enable caching,post atto results after
Will do thanks mate. I'll do this tomorrow now. Am not sure witch ports on my motherboard are sata 3. I know the gray one are but there not intel.
Am using a Asrock Z68 extreme 4 gen3 going to have a google.
silly me :( I thought all the gray ports where marvell but there not only two are from them and the other two are sata3 intel lol
All the black are intel sata 2 where I have other drives installed lol
heres mine,i have the os installed on it now,but ive used it as caching ssd before and read/writes were identical,only difference is the wei score stays the same 5.9 if in caching as the os isnt on it where it score 7.9 if it is,no big deal
ignore the power on times,ive updated to latest ssd firmware a week ago and it resets it
Cool thanks mate. yer noticed the 5.9 thats understandable tho. Even tho am not getting full speed I still noticing super smooth. on start up now I dont even see welcome screen lol then bang all apps loaded.
