- 25 Nov 2011
- The KOP
thats better,are you happy with the corsair gt?
So far it's superb I can't fault it. My pc is super fast.
Which port should I connect the main OS SSD to if the two RAID0 capable SATA3 ports will be occupied by the cache SSD and 1TB drives?- 2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5, Intel® Rapid Storage and Intel® Smart Response Technology), NCQ, AHCI and "Hot Plug" functions
- 2 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M2 connector is shared with eSATA3 port)
youd be better off putting the hdd's on the intel sata2 ports and your ssd's onto the intel sata3 ports
tbh i have no idea on raid,i dont use it,i just thought it would be easier to raid your hdd's on the intel sata2 ports and use your ssd with the os on on the sata3 port alongside your caching ssd also on the intel sata3 port,they wont be part of the array so shouldnt be affected?
maybe someone else who knows more about raid can post,ive only used caching
To install and enable caching (after I've reinstalled windows to my new drive and install the RAID drivers), will I need to format the 1TB drive, or will windows just magically understand the data since installing the RAID drivers?yes it should just cache the drive you want to accelerate
the caching ssd can cache a raid 0 array also,aslong as the os is installed on your other ssd
If you going to be reinstalling windows you might has well enable raid in bios then install. That way when you connect your ssd all the Intel ports are already set to raid. You won't loose any data on the hdd I have 3 hard drives one with windows plus ssd and the other two are data. When switching to raid all my data was fine.
Yes apply the reg tweak and shutdown pc. Connect ssd and power on and enter the bios and switch to raid. Then boot into windows and install Intel smart response and apply caching to the data drive. You can't have separate controller modes they will all be on raid well on my board you can't.
Nope mate its Intel and marvell and Intel smart response only works with Intel ports.
- 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5, Intel® Rapid Storage and Intel® Smart Response Technology), NCQ, AHCI and Hot Plug functions
- 4 x SATA3 6.0 Gb/s connectors
You could put your ssd windows drive on the marvell sata 3 port and set ahci and have just the Intel ports raid that should work. You also wouldn't need to reg tweak just make sure marvell set to ahci before booting.
If I remember correctly, there are two Intel SATA III ports, two Marvel SATA III ports and two Intel SATA II ports?
EDIT: It has 4 of each:
So I'll use one Intel SATA III for the OS SSD, and the two Intel SATA II ports for the SSD caching drive and 1TB docs drive.
All Black are Intel sata2 then you have four gray witch are two Intel sata 3 and two marvell sata3
