- 19 Jun 2012
It is not really surprising, thin Aluminium will bend.
Perhaps they should have used Titanium, but then you could probably add another couple of hundred quid to the retail price.
Or maybe they need to get over the Aluminium fetish, and start thinking about stylish plastics!
Defininately seems like a design flaw though, insomuch as it seems like they have not used material thick enough or with adequate reinforcement in the structure.
However, something that I have not seen explored is whether the issue could be due to internal heat fluxes distorting internal components that then cause the bending rather than just the external case bending due to external forces.
One report I have read was a guy who had the phone in front pockets of loose fitting suit trousers. Should be no physical pressure there really, so perhaps it is a heat issue causing distortion?
Either way, it seems like a gaff of epic proportions!
I blame Bono!! Boo hiss!
