Coz I only need two monitors, I sold the other to go towards the new one![]()
ahhh!
Aren't the LED backlit ones supposed to be not as good for colour critical work such as photography. I think Dell are calling the wider gamut ones 'Premiere Colour' now.
I've got the 27' inch U2711 which I've owned nearly two years now.
It's great, but yes, it does give off a lot of heat. Its actually quite annoying in a small room at home during summer, especially running another monitor and a tower, quickly gets pretty warm.
Only other downside I have to it is that it sometimes gets lines appearing on the left side of the panel, which you have shake the side of the monitor to get it to stop. I read that this is likely due to poor soldering. I need to send it back to OCUK to be looked at when I've got a break in what I'm working on.
^^ If you properly calibrate the monitor then it wont be that bright and the heat will go down (and your elec bill), most monitors are way, way too bright and you need to adjust it down to about 1/4 to 1/3rd of the brightness from the bottom.
I was going to suggest the Asus PA238Q 23 inch for just over £200 but I see you've already bought another one..
